power steering hose leak - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 30th, 07, 01:17 PM Thread Starter
Big daddy
Just finished conversion,it's great,but have small leaks on each hose,they have adapters from Lee's,I prefitted them b4 install.I have since used teflon tape,helped but still seeps. anyone?
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 5 (permalink) Old Apr 30th, 07, 01:41 PM
Re: power steering hose leak
Teflon tape won't help a flare fitting - they don't seal at the threads. They seal at the flare and cone. The nut simply provides clamping force. It sounds like you need to tighten the fittings. Sometimes on a flare it helps to tighten it and back it off and then retighten a couple of times. I'd also recommend using a crow's foot to get at those fittings - it's hard to get a regular tubing wrench in there and get enough leverage to get them tight. I'm assuming it's the fittings on the steering box that are leaking.
BPOS is offline
post #3 of 5 (permalink) Old Apr 30th, 07, 01:56 PM Thread Starter
Big daddy
Yes it is at the bowthey are just small seeps but I don't like seeps,will try what you said,thanks.
carhodge is offline
post #4 of 5 (permalink) Old Apr 30th, 07, 06:40 PM
sonny
last week i did the same conversion. also had the same issues with the seeping, i did what bpos suggested. havent had anymore seeping problems.
67 RS/SS with matching engine, tranny.
67ssrs350 is offline
post #5 of 5 (permalink) Old Apr 30th, 07, 10:08 PM
Make sure to use a back up wrench.
You may have to replace the fittings. If they seep, there may be tiny cracks or a small gall.
I used hard line every where I could and that helped a lot.
mkpatrick is offline
Replacement Part Numbers for Steering/Suspension - LONG HwyStarJoe Brakes, Suspension & Steering 14 Sep 16th, 12 10:50 AM
power steering conversion Barry J Brakes, Suspension & Steering 2 Sep 3rd, 06 03:32 PM
69 Power Steering Hose grossmj Troubleshooting 2 Jul 6th, 06 06:28 PM
'69 power steering return hose clamp Camaro Billy Brakes, Suspension & Steering 2 Mar 9th, 06 04:10 AM
Power Steering Hose Failure. Ideas? Scoop69RS-SS Tech 2002 10 May 3rd, 02 05:21 PM
