Brake idot light flashes - Team Camaro Tech
post #1 of 5 (permalink) Old May 1st, 07, 12:18 PM Thread Starter
Apprentice
I converted the 69 from manual drums to power disks using all vintage/restored parts, no aftermarket. It stops like a cat on carpet now but there is one small nagging problem. When you step on the brake peddle with any amount of enthusiasm, the brake idot light flashes, once. IF you sneek up on em or hold the peddle it doesn't do it. Has anyone seen/cured this in the past. I did recycle the splitter block from the drums but all else is different. The hold of valve (acorn) is a vintage piece I got off ebay, booster and master were rebuilt DM, and calipers are rebuilds. Thanks for any help.
Tuxedo Black '69 RS Convertable with White Z stripes and White Houndstooth interior.
70 Chevelle Malibu Granpa Car, All stock and gonna stay that way
07 FJ Cruiser, it's the dogs car he just lets me drive
02 Corvette, wife's fun car
AnythingButRed is offline
post #2 of 5 (permalink) Old May 1st, 07, 01:27 PM
Blaine
Re: Brake idot light flashes
sounds like you may still have air in the system
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
post #3 of 5 (permalink) Old May 1st, 07, 03:09 PM
Vintage 68's Avatar
The system failure warning light is coming on because the piston in the combination valve/distribution block is not properly centered or is not staying centered. This is that brass stud the wire is attached to in the center of the block.
As stated, it may be some residual air in system causing it to move off-center or the piston got off-center while you were bleeding system. If it is the former (air) then re-bleed to remove any air, if it is the latter (moved while bleeding) then try stabbing (press hard and fast) the brake pedal several times in a row to see if it will move to recenter on it's own.
I have had to replace the valve (worse case) on a few occations as it was sticking and would not recenter correctly.
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 5 (permalink) Old May 1st, 07, 03:21 PM
Harry
dawg's Avatar
get a new combo valve
at least do that cuz with old parts you never know what might fail.
434 stroker
US Navy retired
dawg is offline
post #5 of 5 (permalink) Old May 2nd, 07, 10:38 AM Thread Starter
Apprentice
Thanx for the responses. I will try stabbing and bleeding.
84 camaro Z28 HO , 90K miles ,brake light problem richard mains Third Generation 2 Sep 8th, 05 06:58 AM
Any tips to install brake light switch?? stmay Electrical & Wiring 2 Aug 15th, 05 05:09 PM
rear brake light trouble David Pearson Electrical & Wiring 5 Aug 3rd, 05 03:56 PM
Dash brake light on all the time markatolla Brakes, Suspension & Steering 3 Feb 19th, 03 04:21 AM
Brake Light on Aftermarket Speedo ???? Nats70z28 Tech 2000 1 Jun 1st, 00 05:01 PM
