Would this be a good conversion - Team Camaro Tech
post #1 of 9 (permalink) Old May 1st, 07, 09:18 PM Thread Starter
Jon
This guys lives not to far from me and I was wondering if this is a good setup for a 67 camaro with a 396 4spd. The car I have came stock with drums but it will cost about $200 to fix the front drums so I thought this is a better way to go. Does this kit have everything I will need to convert?
http://cgi.ebay.com/ebaymotors/67-69...03882363QQrdZ1
If the kit is no good who has a good setup? I noticed those calipers looked like single pistons also.
300zxracing91 is offline
post #2 of 9 (permalink) Old May 1st, 07, 09:38 PM
Re: Would this be a good conversion
I would recommend against going with the 2" Drop Spindles! Use 1" or 1.5" drop springs instead, don't use drop spindles on a first gen camaro..
and
Brian Lewis is offline
post #3 of 9 (permalink) Old May 2nd, 07, 10:55 AM Thread Starter
Jon
what is bad about puting the drop spindals on the first gen?
post #4 of 9 (permalink) Old May 2nd, 07, 11:45 AM
It causes interference problems between the steering arm/tie rod end and the wheel. See if he'll give you the same deal but with stock height spindles.
Funny, but in the body of the ad he mentions stock height spindles.
BPOS is offline
post #5 of 9 (permalink) Old May 2nd, 07, 12:20 PM
Blaine
I agree dont use drop spindles. looks like you would need to get the 2 front steel brake lines from the master to the wheel i dont see them in the kit you showed but they should be replaced also..
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
post #6 of 9 (permalink) Old May 2nd, 07, 12:56 PM Thread Starter
Jon
he has stock ride height ones as well. Thanks for the info. How do you guys drop you camaros in the front than or do you guys not drop them.
post #7 of 9 (permalink) Old May 2nd, 07, 05:20 PM
Lowered springs
fireeater is offline
post #8 of 9 (permalink) Old May 2nd, 07, 07:39 PM
Powder Coated Suspension Eibach Front Springs PRO-KIT 1" Drop - Part Number 3848.120 - $123 cardomain.com Free Shipping
and
post #9 of 9 (permalink) Old May 2nd, 07, 08:01 PM
bill
for 484 bux it was a good deal.even if you had to buy both spindles.i paid for a kit from ricks for like 800 bux
jaguareats is offline
Looking for Good BBC Crate Engine tomspo04 Engine 19 Sep 1st, 11 06:55 AM
New 400 SBC owner. Lots of questions. 406 guys come on in! Bipolar Performance 36 Mar 22nd, 06 06:43 PM
Looking for a good car cover LeeMan Camaro Tech 11 Jan 26th, 06 07:43 PM
It is indeed a good day Codi Bench Racing 15 Dec 27th, 05 10:47 AM
'78 Monte calipers any good for disc conversion Willem Brakes, Suspension & Steering 5 Mar 8th, 05 08:11 AM
