hurst roll control - Team Camaro Tech
post #1 of 5 (permalink) Old May 3rd, 07, 03:47 PM Thread Starter
RJ
RJBaileyrn's Avatar
hurst roll control
Hi guys, need help installing Hurst roll control. The directions show 3 types of dual master cylinders routing. I don't see any of them EXACTLY like mine. I have 69 coupe small block with power front discs. The front line on the master cylinder goes to what I think is called a metering block, then right back out to the end of the other block that has the differential switch wire in it. The rear line runs from the master cylinder to the other end of the differential block. From this block, the lines go to the rear brakes, the right front brake and the left front brake, WHEW. what type do I have, #1, #2, or #3. And does anyone have a picture of this install that will help me before I disconnect lines. I know you guys know the answer. Please be specific. thanks so much
rj
RJBaileyrn is offline
post #2 of 5 (permalink) Old May 3rd, 07, 04:42 PM
Larry
Re: hurst roll control
put it in the rear line coming out of the master (the larger of the 2 resivoirs)
Any place before the lines split will work, all it does is maintain pressure when you're on the switch and have stepped on the brake. Other than that, it just rides along doing nothing, and has no effect on braking.
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ls427ss is offline
post #3 of 5 (permalink) Old May 3rd, 07, 04:54 PM Thread Starter
RJ
RJBaileyrn's Avatar
If I put it in the rear line, then it will lock up all four wheels won't it?
rj
post #4 of 5 (permalink) Old May 3rd, 07, 05:43 PM
With your setup, I would do it this way.
1) Disconnect the lines going to the two front wheels from the distribution block (the rectangular block underneath the master). These will be the right front line, and the very front line.
2) Put a plug in the right front outlet port.
3) Plumb a line from the very front port to the line lock inlet.
4) At the line lock outlet, install a Tee fitting.
5) Connect the right and left wheel lines to either end of the tee.
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Kyvox is offline
post #5 of 5 (permalink) Old May 4th, 07, 01:19 AM
rj
No, not at all.
BlackoutSteve is offline
Stash of NOS GM control arms found ! NEED HELP WITH ID .. DynoTom Brakes, Suspension & Steering 4 Oct 16th, 06 07:53 PM
No Hurst Name On 68 Shifter??????????? gonewacky Transmission & Driveline 9 Sep 13th, 06 05:33 PM
"correct" rear roll center height Ed Bleich Brakes, Suspension & Steering 2 Dec 3rd, 04 04:27 PM
The answer to GW control arms with the Guldstrand modification chicane67 Brakes, Suspension & Steering 8 Mar 20th, 03 08:22 AM
