Drum brake backing plates - Team Camaro Tech
post #1 of 5 (permalink) Old May 4th, 07, 05:18 PM Thread Starter
JcGc's Avatar
Does anyone know what size nuts and bolts hold the stock drum backing plates to the rear axle housing. I can't find the ones I took out when I tore the rear end apart.
JcGc is offline
post #2 of 5 (permalink) Old May 4th, 07, 05:24 PM
Re: Drum brake backing plates
3/8-24
1 1/4" should be plenty long enough. Use grade 8 and use lockwashers.
BPOS is offline
post #3 of 5 (permalink) Old May 4th, 07, 06:32 PM Thread Starter
JcGc's Avatar
Bpos,
Thanks for the info, I really appreciate it.
Will stainless nuts and bolts be strong enough.
JcGc is offline
post #4 of 5 (permalink) Old May 4th, 07, 10:39 PM
Blaine
mine were 3/8" X 1" fine thread grade 8 with lock washers don't think you really need stainless they could gall up if you dont use antiseize
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
post #5 of 5 (permalink) Old May 5th, 07, 09:58 AM
BonzoHansen's Avatar
Originally Posted by JcGc View Post
Bpos,
No. GM used GR8.
TC Member #13
BonzoHansen is offline
Rear Brake Drum Weights Johnny B Brakes, Suspension & Steering 6 Mar 19th, 07 01:09 PM
Disk Brake vs. Drum Brake Spindles fast_eddie Brakes, Suspension & Steering 8 May 29th, 06 12:13 PM
Disc backing plates RobR Brakes, Suspension & Steering 1 Apr 13th, 06 06:39 PM
Disc Brake Splash Plates John69ss Brakes, Suspension & Steering 4 Mar 22nd, 00 08:20 PM
