column to gear box alignment - Team Camaro Tech
post #1 of 11 (permalink) Old May 6th, 07, 08:05 AM Thread Starter
joe
Send a message via AIM to zbo2
Unhappy column to gear box alignment
i'm having a problem getting the steering wheel to line up properly. 69Z w/power... the gear box is centered and the wheels are straight however when i go to hook up the column the steering wheel is 3/8's of a turn to the left. the gear box shaft has a flat spot like the rag joint so that can only go on 1 way, and the column has only one way the the rag joint can go on so the bolt will pass through. the horn button on the wheel end of the column can only go on 1 way also. any help will be appreciated!
Joe
69 Z-28 Fathom Green />93 Z-28 Pace Car/>86 Corvette...Red
zbo2 is offline
post #2 of 11 (permalink) Old May 6th, 07, 09:34 AM
Ted
Re: column to gear box alignment
You might have to pop the steering wheel off and readjust it.
tgifford5 is offline
post #3 of 11 (permalink) Old May 6th, 07, 12:42 PM
Are you sure the pitman arm is on right and your box is centered?
go2fast is offline
post #4 of 11 (permalink) Old May 6th, 07, 02:15 PM Thread Starter
joe
yup................box is centered, tie rods are centered on both sides, pitman arm is pointing straight forward wheels are straight. the steering wheel can only go on 1 way since the cam or retainer for the horn button can only go on 1 way. it's a tilt column, the only thing i'm not sure of is if there is a way inside the column to adjust the alignment.
Joe
zbo2 is offline
post #5 of 11 (permalink) Old May 6th, 07, 03:12 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Is this a rebuilt tilt column? If so, it could be assembled improperly. My rebuild column is assembled wrong, but it's a 68 so I can put the steering wheel anwhere and still feed the horn button through.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #6 of 11 (permalink) Old May 6th, 07, 04:01 PM Thread Starter
joe
i'm comming to that conclusion.....that the gear box was rebuilt. not the column....with the column it would be 180 degrees out. i've been working on this car for a while. i remember getting a rebuilt gear box quite a while ago......but i thought it was for my truck.........maybe it was for this car. this getting old stuff is not all it was cracked up to be. anyhow what i did was on the rag joint, i took my air grinder and releived the flat spot just a hair and got it to go on the way i need it. with all the splines i doubt that it would be a problem. sounds worst than it was. thanks for the responses...
Joe
zbo2 is offline
post #7 of 11 (permalink) Old May 7th, 07, 06:02 AM
Jon
Rodder's Avatar
If you got a Chinese repro rag-joint, the holes are drilled wrong which would force you to install the column 180 degrees off.
Rodder is offline
post #8 of 11 (permalink) Old May 7th, 07, 06:53 AM
There is a window in the steering column locking plate that allows the horn tower to rotate a slight amount. You might be able to clock the horn tower clockwise enough so that the steering wheel hub will install one or two serrations. One serration on the steering shaft should be 12 degrees (360/30 = 12). That might get you half way there. Then you should be able to adjust the tie rods to fully center the steering wheel.
Here is a link to a steering centering paper,
http://jimshea.corvettefaq.com/wp-co...Rev18MY062.doc
JIML82 is offline
post #9 of 11 (permalink) Old May 7th, 07, 07:49 AM
mike
after assembling the wheel to the mark on the shaft you will have to adjust your tie rods to center the wheel
remember what ever you do on one side do the opposite on the other side
mike
mikeyparts is offline
post #10 of 11 (permalink) Old May 7th, 07, 08:48 PM Thread Starter
joe
rodder............no chinese joint....original gm.
jiml82.............yea...that would not even get me half way there, and still to far off to get the wheel straight with the tie rod adjustment.
mikey.............i'm just being anal i guess.....but the way i figure it is everything should work out with all the stuff centered. if i have to start compensating for the problem i think that's just going to be compounded in the end. the tie rod ends should be just to get the final toe in adjustment not to turn the wheel 20 degrees to get it straight. i'm really leaning on the theory that the gear box was assembled wrong. i've got it straight now with some minimal beveling of the flat spot on the rag joint.
Joe
zbo2 is offline
post #11 of 11 (permalink) Old May 7th, 07, 09:00 PM
Send a message via AIM to RamAirDave
This recent thread dealt with a similar issue. Might help, might not.
https://www.camaros.net/forums/showthread.php?t=106660
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
man gear box install stamatisg1977 Brakes, Suspension & Steering 1 Apr 29th, 07 06:25 PM
AGR power steering gear box Mister G Brakes, Suspension & Steering 9 Nov 14th, 06 08:45 AM
Power steering gear box desertracing007 Brakes, Suspension & Steering 1 Nov 6th, 06 08:12 PM
Acceptable Gear Pitting PL7481 Transmission & Driveline 2 Aug 23rd, 05 04:47 PM
Dashboard Column Shift T-350 or T-400 Gear Indicator CamarosRus Interiors 1 Nov 14th, 04 11:23 AM
