Coil overs - Team Camaro Tech
post #1 of 4 (permalink) Old May 6th, 07, 04:46 PM Thread Starter
68weekendwarrior's Avatar
Coil overs
Hey,
Just put rear coil overs and ladder bars on my 68 camaro. The car leans bad to the passenger side rear. There is about 1 inch difference from the other rear side. Could this be a adjustment? or could it be coming from the front springs? or can I run a stiffer spring on the right rear? Thanks
68weekendwarrior is offline
post #2 of 4 (permalink) Old May 6th, 07, 05:02 PM
bill
Re: Coil overs
if you racing it is wrong. the drivers side should be lower than right in the rear.as you give it gas the drivers side in front comes up than rear is evened out.so think you got the bars not adjusted it right.
jaguareats is offline
post #3 of 4 (permalink) Old May 7th, 07, 08:53 AM Thread Starter
Re: Coil overs
The bars are in he same holes, and the shocks are in the same holes on the brackets, but I dont know if the shocks ans springs are right as far as adjustment with number of turns, can i go back on the number of turns and start over? Thanks
post #4 of 4 (permalink) Old Jun 12th, 07, 05:39 PM
Re: Coil overs
how do you put rear coils on a 69? kit?
rustycarr is offline
Front Coil Springs vs Coil Over's HELP 68RSboom Brakes, Suspension & Steering 3 Apr 10th, 07 01:47 PM
Dropped spindles VS. Adj Coil overs or Both DirtyScotty Brakes, Suspension & Steering 3 Oct 5th, 06 12:42 PM
Hotchkis Coils, QA1 Coil Overs and Tubular A-Arms? eville Brakes, Suspension & Steering 5 Dec 30th, 05 06:22 AM
coil overs? gieske's71nova Brakes, Suspension & Steering 0 Dec 11th, 05 09:37 PM
Coil overs for a first gen Camaro Mark .L.W. Brakes, Suspension & Steering 34 Mar 9th, 04 06:42 PM
