Low Brake Pedal - Team Camaro Tech
post #1 of 7 (permalink) Old May 6th, 07, 06:07 PM Thread Starter
Low Brake Pedal
After installing a new rear in my 67 Camaro, I decided to convert to rear disc. After completing the installation I found that the brake pedal is low. As you immediately press the pedal the front brakes apply but , the rear do not apply untill half way through pedal travel. The car has small piston GM calipers (79 Monte Carlo style) all around, stock proportioning valve, and a manual brake master cylinder. Before the conversion the car had rear drums with all the components listed previously. Im thinking that I may need to have a different master, one for power brakes since the piston is larger(I believe?). Thank you in advance, I'm sure you guys can help me!
K-Performance is offline
post #2 of 7 (permalink) Old May 6th, 07, 09:07 PM
Blaine
Re: Low Brake Pedal
I think your right i believe you need a disc/ disc master.
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
post #3 of 7 (permalink) Old May 7th, 07, 05:00 AM
Doug
DougP's Avatar
Re: Low Brake Pedal
I have been told that the master cylinder for disc brakes was larger than the one for manual brakes
==Doug
Former
owner
Former
owner
Former 2nd
owner (
DougP is offline
post #4 of 7 (permalink) Old May 7th, 07, 09:53 AM
David Pozzi
davidpozzi's Avatar
Re: Low Brake Pedal
1 1/8" bore is standard for disc or drum, the disc brake master cyls have a larger reservoir than drum MC's.
Those rear calipers you installed often have low pedal problems. The first thing to try is operating the emergency brake off and on to get them to self adjust.
Look for excessive play of the brake pads on one rear caliper, that may indicate the bad one.
davidpozzi is offline
post #5 of 7 (permalink) Old May 7th, 07, 09:56 AM
BonzoHansen's Avatar
Re: Low Brake Pedal
Based on 79 Monte Carlo, I am guessing he has front calipers at all 4 corners.
TC Member #13
BonzoHansen is offline
post #6 of 7 (permalink) Old May 7th, 07, 01:43 PM Thread Starter
Re: Low Brake Pedal
Correct, I have front brake calipers all around with no e-brake. After doing other research, I agree with Blaine. I was thinking of trying a disc/ disc master cylinder from a 69 Corvette to increase the volume which I believe I'm currently lacking. Any opinions?
post #7 of 7 (permalink) Old May 7th, 07, 09:56 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Re: Low Brake Pedal
C3 Vette master cylinder is 1 1/8 bore meant for 4-wheel discs. That's what I'm running on mine now, and it feels a lot better than my old disc/drum (1" bore I think) master felt. Pedal still feels a little soft to me sitting still, but I'm chalking that up to running hydroboost--it'll put you through the windshield long before the pedal is hard.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
Brake Pedal Doesn't come all the way back up- Lights stay on.. 1967rsss350 Troubleshooting 13 Mar 10th, 16 01:05 PM
Brake Pedal Gone. What happened?? fastercar68 Brakes, Suspension & Steering 7 Oct 8th, 06 01:32 PM
69 Brake pedal position piece madmax87 Brakes, Suspension & Steering 4 Sep 20th, 06 10:33 AM
disc brake pedal depressed jason69rs/ss Brakes, Suspension & Steering 1 Jul 11th, 06 07:01 PM
Low Pedal lucky13 Brakes, Suspension & Steering 3 Sep 29th, 05 06:28 PM
