Need torque specification - Team Camaro Tech
post #1 of 2 (permalink) Old May 7th, 07, 03:29 PM Thread Starter
Jon
I cant find the torque specification for the nut that goes on the spindal and pretty much holds the rotor in place.
300zxracing91 is offline
post #2 of 2 (permalink) Old May 7th, 07, 07:58 PM
Re: Need torque specification
If you are talking about the wheel bearing pre-load, torque the spindle nut to 12 ft lbs. If the cotter pin lines up , install it. If it doesn't, back the nut off until it it does.
BPOS is offline
Comp Cams XE274H-10 Chris-in-Cali Performance 26 Aug 26th, 07 03:57 PM
rod bolt torque ctrghtous Engine 7 Sep 30th, 06 11:02 PM
Whats the key to throttle response? 67CamaroD Performance 44 Apr 23rd, 05 08:08 AM
VOLUMETRIC EFFICIENCY /ENGINEs torque CURVE grumpyvette Performance 4 Mar 25th, 02 04:51 PM
torque vs horsepower b-boy Engine 9 Jan 15th, 01 03:33 PM
