Leaf spings, mono or multi? - Team Camaro Tech
post #1 of 3 (permalink) Old May 9th, 07, 11:07 AM Thread Starter
This might be something really simple but something I have always wondered about. What is the difference between a multi leaf shackle and a mono? Other than the obvious, one being stronger than the other. Why would they use a mono if a multi is better? Did the rs model come stock with a mono? I have a 68 rs and it has the mono leaf shackles, but my 68 I had 20 years ago was a stock coupe with multi leafs with the same motor as the rs ( 327 ). Can someone shed some light on this?
Ken mac/66 Chrysler convertible<br />/69 firebird/68rs camaro.
Ken/68RS is offline
post #2 of 3 (permalink) Old May 9th, 07, 11:52 AM
DjD
DjD's Avatar
Re: Leaf spings, mono or multi?
Ken - I believe there was just one shackle used not a seperate one for mono and multi leafs. Are you refering to spring perches and shock plates by chance?
RS was a dress-up package. Any Camaro could get the headlights and trim items. It had no bearing on springs.
...Dennis
DjD is offline
post #3 of 3 (permalink) Old May 9th, 07, 04:36 PM
Banned
Now the later '68/'69 staggered stud shock plates are a lot heavier than the through-bolt non-staggered '67 plates b/c through-bolt is actually stronger so the metal can be thinner.
This is b/c the later stud jobbers have to be a lot heavier to resist the stud's bending moment on the plate..
Hope this helps..
pdq67
Split mono leaf verses multi leaf Liveinaz Brakes, Suspension & Steering 1 Dec 9th, 06 10:59 AM
mono to multi leaf conversion drilling a center hole coffeeguy Brakes, Suspension & Steering 13 Mar 2nd, 06 09:04 PM
Mono leaf VS multi leaf springs LukeSkywalker Brakes, Suspension & Steering 12 Sep 21st, 05 04:53 PM
mono leaf to multi leaf YC69camaro Transmission & Driveline 3 Dec 28th, 04 12:12 AM
mono vs. multi leaf tdks Engine 2 May 15th, 01 08:07 AM
