bushings, poly vs rubber - Team Camaro Tech
post #1 of 18 (permalink) Old May 9th, 07, 09:13 PM Thread Starter
ed
I am getting ready to redo complete front end . Would like to get input on the best product for replacing all my bushings including subframe. I have heard poly are better, but I have had some say the squeak. Thanks.
ironblue96 is offline
post #2 of 18 (permalink) Old May 9th, 07, 09:21 PM
Re: bushings, poly vs rubber
Use plenty of PolyLube, available at Autozone and you won't have any squeaking problems. I have the full Energy Suspension kit on my cars, no squeaks.
and
Brian Lewis is offline
post #3 of 18 (permalink) Old May 10th, 07, 05:37 AM
If you have the coin, the best bushings are hard plastic. Del-a-lum from global west is one example.
Rubber= lots of deflection, some friction.
poly= little deflection, lots of friction.
del-a-lum=zero deflection, almost zero friction.
Unfortunately, del-a-lum bushings run about $140.
post #4 of 18 (permalink) Old May 10th, 07, 06:03 AM
Edd
I got Poly in My Subframe and Suspension NO Squeaks at all just lots of better handling and tighter feel.
Edd Gordon 68 Camaro SS350 now SS 406 96 SLP SS Camaro
edd Gordon is offline
post #5 of 18 (permalink) Old May 10th, 07, 07:01 AM
Yep I run these black graphite poly kits from Eibach, no squeaks after 3 years
Energy Suspension Body Bushings - Part Number 3.4142B
Energy Suspension Control Arm Bushings - Part Number 3.3101B
Energy Suspension Control Arm Bumpers - Part Number 9.9154R
Energy Suspension Transmission Mount - Part Number 3.1108G
Get the Energy Suspension Formula 5 Pre Lube Part # 9-11110 (4.5oz) or 9-11104 (8oz) and lube everything real good. The kits above come with some prelube but not enough to coat everything. I also use the same on any bushings including shocks and swaybar bushings.
and
post #6 of 18 (permalink) Old May 10th, 07, 07:18 AM
Tim
Like Brian said! They work great and I've heard no squeaks.
1969 SS Convertible, LeMans Blue w/White Stripes, 383, 350 Turbo, 650 Demon mech. sec., DSE subframe connectors and Caltracs etc.
h
blue69camaro is offline
post #7 of 18 (permalink) Old May 10th, 07, 05:01 PM
Banned
I'm w/ Brian here about the graphite filled poly!!
pdq67
post #8 of 18 (permalink) Old May 10th, 07, 05:27 PM
I have poly subframe bushings. Will never go back to rubber.
They make the car feel very solid and it turns and handles corners better
'69 Z/28 X33 D80 V0105DZ DNE 4+1
'98 Z28 M6
mikes69z is offline
post #9 of 18 (permalink) Old May 10th, 07, 05:33 PM
Just don't forget the snot grease on the ends.
TC # 349
zdld17 is offline
post #10 of 18 (permalink) Old May 10th, 07, 05:49 PM Thread Starter
ed
Thanks for the input. Matts classic bowties shows a polyplus kit, is this the same as Energy suspension as far as product? The info on both seem the same. Also can you tell me why all kits for 67 are more expensive than 68-69. From what I can tell there are the same amount of parts.
post #11 of 18 (permalink) Old May 10th, 07, 06:39 PM
Energy Suspension Body Bushings - Part Number 3.4142G
$56 free ship at http://carpartsplanet.com/product.php?productid=28124
Energy Suspension Control Arm Bushings - Part Number 3.3101G
$54 http://autotruckpart.com/product.php?productid=322737
$17 free ship http://carpartsplanet.com/product.php?productid=28779
and
post #12 of 18 (permalink) Old May 11th, 07, 06:34 AM Thread Starter
ed
Brian, thanks for your help. I found a site- Performance Suspension Components- that has a complete rebuild kit for $330.00. They state this a Energy Suspension kit. They also state that bushings are grafite inpregnated, but Energy Suspension's site does not state this. I am curious is it a true Energy Suspension bushing. I also don't see on Energy's site where they offer anything but the bushings.
post #13 of 18 (permalink) Old May 11th, 07, 10:58 AM
The 3 parts I listed are 3 kits, total cost is around $130, alot cheaper than $330! Body Bushing Kit comes with all new bolts/washers (see picture below). The G in the part # means Black GRAPHITE.
and
post #14 of 18 (permalink) Old May 11th, 07, 04:56 PM
Banned
Awe, GEEE!!
That's some "BUSHING PORN" ta me!!
He, He!!
pdq67
post #15 of 18 (permalink) Old May 12th, 07, 05:20 AM Thread Starter
ed
Cool, the reason for added expense for kit I was looking at had all bushings plus ball joints with poly boots, tie rod ends, idler arm etc., it was a full kit. I figured why it was all apart replace it all. Better now then doing part of it then something giving out and replacing anyway. What I will do is shop around to out source other parts to compare price. Thanks again Brian.
poly rear spring bushings KURT Brakes, Suspension & Steering 1 May 3rd, 06 04:49 PM
Poly Bushings: Help or Hurt Dragstrip Traction ???? my69gofast Brakes, Suspension & Steering 4 Jun 19th, 04 03:09 AM
Poly vs rubber A-arm bushings 69rad Brakes, Suspension & Steering 4 Feb 2nd, 04 10:00 AM
Poly body bushings users....requesting your input please. Granny's 69 Brakes, Suspension & Steering 17 May 22nd, 03 01:14 PM
rubber vs poly bushings? 19topless69 Brakes, Suspension & Steering 13 Apr 11th, 02 04:11 AM
