power brake booster vs low vacuum - Team Camaro Tech
post #1 of 8 (permalink) Old May 10th, 07, 07:26 PM Thread Starter
Russ
Does anyone know how much vacuum is required to operarte the power brake booster. I want to install a chrome power brake booster and master cyl. assembly , I was looking at the 7" or 8" assembly for mine due to having a big block with tall valve covers. Car currently has 11" of vacuum at idle. Will that cut it?
Russ
1969 RS conv,hugger orange,396 4 speed,373 12 bolt posi.
19694speed is offline
post #2 of 8 (permalink) Old May 10th, 07, 08:11 PM
Re: power brake booster vs low vacuum
i have the same vacuum with my stroked small block and it works just fine. it has a mildly 'lopey' idle at 650-700 rpm and i've never had any problems. the brake companies want at least 18 inches or so of vacuum at idle, but if the check valve and booster are sealed and working properly, you should be able to store a higher vacuum in the booster after start-up and driving around for when you need it.
guccieng is offline
post #3 of 8 (permalink) Old May 10th, 07, 08:13 PM
john
wagonman's Avatar
i have 6 in hg at idle with my croosram motor and the brakes still work fine!!!!
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #4 of 8 (permalink) Old May 10th, 07, 08:27 PM
Steven
stamatisg1977's Avatar
or if you are still unsure, add a vacuum reserve can and mount it on drivers inner fender well. it will give the booster the extra needed vacuum when brakes are applied
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #5 of 8 (permalink) Old May 11th, 07, 09:49 AM
Robert
According to the people at Right Suff Detailing (800-405-2000) all vacum boosters need a minumun of 16 -18 inches of vacum. If you are going to go to a smaller diameter you should look into their Dual Slimline. By adding a second diaphram you will increase the assist 25-30%.
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
68Holdon is offline
post #6 of 8 (permalink) Old May 11th, 07, 01:18 PM
Matt Jones
Smaller boosters require more vacuum for the same amount of assist. In this case, bigger is better.
I've run boosters down to 11-13" vacuum and the brakes still felt good. Think about the DZ Z/28 motors...they didn't produce much vacuum, either. I'm not sure where the "16 in Hg minimum" came from...
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #7 of 8 (permalink) Old May 11th, 07, 01:40 PM
I was running 6 to 7 with my big block and started to have issues. I then pulled it and stuck in the hydraboost. Not cheap but not stopping when you need comes at a much higher cost........
Mister G is offline
post #8 of 8 (permalink) Old May 12th, 07, 05:28 PM Thread Starter
Russ
Thank's for the replies everyone.
Russ
Power Brake Booster Vacuum Pressure fatbaby New Member Introductions 2 Jan 7th, 07 11:21 PM
DUMB Question - Power BRAKE Booster greg1ontheedge Brakes, Suspension & Steering 5 Jul 25th, 06 06:47 AM
9204 Power Brake Booster burntbunz Restoration Corner 4 Nov 2nd, 05 05:27 PM
getting too hot noels69 Heating & Cooling 14 May 31st, 05 07:53 PM
power brake booster 69ss350camaro Brakes, Suspension & Steering 2 Dec 7th, 04 03:05 PM
