Disc conversion brake line question - Team Camaro Tech
post #1 of 7 (permalink) Old May 10th, 07, 08:56 PM Thread Starter
Jon
I installed the front brake conversion to my 67 non-power disc brakes and not the brake lines that go to the device below the master cylinder do not conect. What should I do? If I go to stainless steel line that would cost a lot of cash.
300zxracing91 is offline
post #2 of 7 (permalink) Old May 10th, 07, 11:09 PM
Blaine
Re: Disc conversion brake line question
Did you go with power disc? New front brake lines came with my power disc kit. if your's didn't you should replace them. no need to really go stainless if you don't want to. I don't think there all that expensive
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
blainedoe is offline
post #3 of 7 (permalink) Old May 11th, 07, 05:15 AM
If you went from drum to disc. The lines are diferent . you can get aluminum resonalble. Make sure you tell them the combo valve you are useing with your kit. Lots of them come with 71-81 style valve.
blue ss is offline
post #4 of 7 (permalink) Old May 11th, 07, 06:43 AM Thread Starter
Jon
How do you know what combo valve you are using? It also seems that the wire that plugs in does not plug in correctly.
post #5 of 7 (permalink) Old May 11th, 07, 08:11 AM
Use steel tubing for your hard lines. If you have a decent flaring tool, you can bend and flare your own front brake lines for about $10 total. I just did mine this weekend. The 3/16 steel brake line is very easy to bend by hand - no special tool needed there. If you do your own flares, make sure they are DOUBLE flares. Single flares are a no-no for brake lines. Stainless tubing is a whole 'nuther animal - way more expensive and much more difficult to flare. Granted - it's prettier, but regular steel tubing will probably outlast the car.
BPOS is offline
post #6 of 7 (permalink) Old May 11th, 07, 10:32 AM
http://www.drclassic.com/catalog/Cam...ke/Y00072.html
This is a 70s style this place can get you prebent line sets
blue ss is offline
post #7 of 7 (permalink) Old May 11th, 07, 10:34 AM
If that is the conbo valve your original conector can work you have to push the wire though its cup and then stuff it in the combo valve. Then slide the cup back down.
blue ss is offline
disc brake conversion gotsnappy Brakes, Suspension & Steering 3 Jan 16th, 07 11:21 AM
Disc Brake upgrade question for Aussie Camaro AussieCamaroOwner Brakes, Suspension & Steering 1 Feb 6th, 06 08:54 AM
Power Disc Brake Conversion worthamterrence Brakes, Suspension & Steering 12 Aug 27th, 05 04:58 PM
Brake Bleeding the right way WillS Brakes, Suspension & Steering 0 Feb 14th, 05 03:45 PM
