67 camaro/front suspension - Team Camaro Tech
post #1 of 2 (permalink) Old May 11th, 07, 06:40 PM Thread Starter
James
Question 67 camaro/front suspension
need to change all front rubber bushings tie rod ends ,ball joints,adjusting sleeves,idler arm , sway bar link kit and new coil springs. can anyone tell me where to buy a good front suspension kit and what I'll expect to pay ?
s-mans67 is offline
post #2 of 2 (permalink) Old May 11th, 07, 07:14 PM
Gary
TraxUnderground's Avatar
Re: 67 camaro/front suspension
I just did mine on my 67 rs. Check out Just Suspensions or PST. I used a polygrahite kit. I bought the kit from Just Suspensions and they have been great with any support. I bought the frame bushings and the rear spring bushings from PST. Great to work with also. Wherever you get your kit from make sure that the bump stops are the ones for a 67. The 67 bump stops mount on a frame perch facing down at the lower arm. All othet 1st gens have them mounted on the bottom arm. I called them and they sent me the correct ones. I bought my big block springs from Just Suspensions too. It cost me $616 for the coil springs, Super Stock Suspension kit and the 1 1/8" swaybar kit. It was all polygrahite. The rubber kit was cheaper.
Good luck !
Gary
67 RS Resto-Mod 468 5 spd TKO600 3.73 12 bolt (work in progress but finally on the road!)
73 Camaro project in a million pieces
TraxUnderground is offline
The last 67 Z 28 ?? iluv69s Tag Team 24 Nov 23rd, 06 05:00 PM
67 rear frame rail separation distance rjg67rs Body Shop 3 Sep 1st, 06 12:04 PM
Need help with suspension recommendation Kirk Brakes, Suspension & Steering 2 Feb 25th, 04 08:23 AM
Suspension Parts List davidpozzi Brakes, Suspension & Steering 3 Feb 23rd, 04 01:54 AM
