Power brake booster differences - Team Camaro Tech
post #1 of 8 (permalink) Old May 12th, 07, 08:56 AM Thread Starter
Dan
What is the difference between an 11 inch stock 1969 booster and a new 7 inch two stage booster.
ranger is offline
post #2 of 8 (permalink) Old May 13th, 07, 01:01 AM
Re: Power brake booster differences
4 inches?
400bird is offline
post #3 of 8 (permalink) Old May 13th, 07, 01:06 AM
but seriously
the dual diaphragm 7" booster has 76.93 sq in. to apply assist with
the stock 11" booster has 94.99 sq in.
a dual 8" booster would be about the same as stock about 100 sq in.
or did you mean in appearance?
check these guys they have lots of pictures
http://hotrodsusa.com/
400bird is offline
post #4 of 8 (permalink) Old May 14th, 07, 03:01 AM Thread Starter
Dan
So then it would take more foot pressure to apply the brakes using the 7 inch 2 stage booster?
ranger is offline
post #5 of 8 (permalink) Old May 14th, 07, 05:39 AM Thread Starter
Dan
Okay. Now that I know that it requires more foot pressure to use the 7 inch booster here is the problem.
The pedal does feel harder but when stopping at a stop sign the first push of the brake pedal feels normal then the second push is firmer and the third push is like manual braskes you got to push very hard.
Why could this be hapenning?
ranger is offline
post #6 of 8 (permalink) Old May 15th, 07, 02:21 AM
if your engine makes a lot less than 16" of vacuum at idle, what you are saying sounds about right
there is a check valve in the line to the booster to hold the peak vacuum inside the booster, which will give you one really well assisted braking
then each additional push has less engine vacuum to assist you
400bird is offline
post #7 of 8 (permalink) Old May 15th, 07, 03:04 AM Thread Starter
Dan
Does anyone else have this same problem and is there a fix for it?
ranger is offline
post #8 of 8 (permalink) Old May 15th, 07, 11:43 AM
Fred
Never heard of a fix. It's the nature of vacuum assisted brakes. Use up the vacuum=no more assist.
128.79mph 1.428 60'
Fred Ficarra is offline
9" power brake booster problem... GWM 68 Brakes, Suspension & Steering 4 Mar 13th, 06 06:00 PM
9204 Power Brake Booster burntbunz Restoration Corner 4 Nov 2nd, 05 05:27 PM
Power Brake Booster number DSimoni Tag Team 0 Jul 1st, 03 09:13 AM
changing brake booster to manual brake JCAMARO Tech 2000 1 Dec 28th, 00 12:05 PM
Power brake booster restoration gheatly Brakes, Suspension & Steering 7 Aug 27th, 00 05:52 PM
