Drum Brakes, no pedal. - Team Camaro Tech
post #1 of 4 (permalink) Old May 13th, 07, 03:36 PM Thread Starter
MaryBeth
This one is for the 55 Nomad. Drum brakes all the way around. Brakes have been bled and fluid in all locations. Pads are new. What are we missing? I thought some of you gurus might be able to provide some insight.
MaryBeth's 67 moneypit
mbmmca is offline
post #2 of 4 (permalink) Old May 13th, 07, 03:58 PM
Kevin
KevinW's Avatar
Re: Drum Brakes, no pedal.
2 things to check. Did you adjust the shoes before putting the drums on? 2nd, is the master new or power? There have been issues with the wrong length pushrod. if the master is old, possible the master is leaking internally.
Kevin
KevinW is offline
post #3 of 4 (permalink) Old May 13th, 07, 05:28 PM Thread Starter
MaryBeth
To answer the first question, I don't think so. Hubby was thinking that as well. As to the second, The master cylinder is 2 yrs old, as is the booster...will check the shoes first. Thanks.
mbmmca is offline
post #4 of 4 (permalink) Old May 13th, 07, 06:03 PM
bill
all got to be adjusted right before bleeding. that way need pressure on brakes to push air out.
jaguareats is offline
My drum brakes screech after a few miles: bdzee Brakes, Suspension & Steering 3 Feb 28th, 07 06:37 PM
Drum brakes and plus size wheels? help canadianbacon Wheels & Tires 6 Apr 27th, 05 10:21 AM
rear drum brakes lock up ,front disc are fine,68z28 68 rs z28 Brakes, Suspension & Steering 15 Apr 9th, 04 02:23 PM
How do you adjust drum brakes ? jr68 Brakes, Suspension & Steering 5 May 24th, 03 02:47 AM
11" Rear Drum Brakes 1968DON Brakes, Suspension & Steering 7 Mar 8th, 02 04:19 AM
