69 camaro rear shock diffrence between mono or multi leaf - Team Camaro Tech
post #1 of 21 (permalink) Old May 13th, 07, 05:13 PM Thread Starter
bigsteve
Would like to know what is the diffrence between mono leaf shocks and multi leaf shocks? thanks
bigsteve is offline
post #2 of 21 (permalink) Old May 13th, 07, 06:07 PM
bill
Re: 69 camaro rear shock diffrence between mono or multi leaf
in 67 they had mono springs which is straight shocks. in 68 they went to staggered mounts shocks for better traction or less wheel hop.also to multi leaf springs.
jaguareats is offline
post #3 of 21 (permalink) Old May 13th, 07, 06:22 PM
The main difference in the shock is the configuration of the lower mount.
The mono leaf spring plates "sandwich" the shock, metal on both sides, and the shock is attached with a through bolt.
Multi plates only have one much thicker ear, not a sandwich. The shocks hardware kit contains a kinda big stud thing, which passes thru the shock plate bracket and is nutted, and the other end passes thru the shock and is also nutted.
I'm not sure if the lower shock mounting grommet is different, I think the one for multi's will have a larger OD.
Some have said the shocks are different lengths, multi's slightly longer,I've never checked that.
post #4 of 21 (permalink) Old May 13th, 07, 08:20 PM
Jim is correct. Shocks for a multi are slightly longer, and have a larger ID rubber bushing to go over the mounting stud/bolt.
Eric
Eric Kammerer is offline
post #5 of 21 (permalink) Old May 13th, 07, 08:22 PM
Rick
does anyone have a picture of the multileaf shock set up?
I am concerned that the bilstein shocks I have for my 68 may not be for a monoleaf setup.
Rick
dukemd66 is offline
post #6 of 21 (permalink) Old May 13th, 07, 08:31 PM
DjD
DjD's Avatar
Multi leaf shocks have a stud built into the bottom mount of the shock. Mono have a hole for a bolt... Well at least Koni's do...
...Dennis
DjD is offline
post #7 of 21 (permalink) Old May 14th, 07, 04:48 AM Thread Starter
bigsteve
My camaro had mono leaf and was converted from mono to multi leaf but the bracket the shock connects to is from the mono leaf set up. The shocks connect off set and are bolted in between the bracket. For Future refranca should I keep using mono shocks or could I use multi leaf shock with this mono bracket? Would it be better to convert to a multi leaf bracket so I can use the correct lenth/bolt style shock for the multi leaf springs I am using on the car? thanks for the help
bigsteve is offline
post #8 of 21 (permalink) Old May 14th, 07, 04:58 AM
Banned
Mono shocks bottom hole should be 3/8" dia if I remember right.. Multi stud hole more like 1/2" or 9/16".....
I had H-D, multi Monroes on my car and I just took a piece of tubing and notched it and shimmed the holes down years and years ago..
pdq67
post #9 of 21 (permalink) Old May 14th, 07, 07:02 AM Thread Starter
bigsteve
were you able to use the emergency brake retainer bracket that the mono bracket has with the multi leaf springs?
bigsteve is offline
post #10 of 21 (permalink) Old May 14th, 07, 09:04 AM
David Pozzi
davidpozzi's Avatar
My shock and spring perch info:
http://www.pozziracing.com/rear_susp...r%20Shocks
You can convert a mono leaf shock to multi leaf by adding the stud to the lower shock eye, but you need a Multi-Leaf spring plate. Shock lengths are the same, but plates have different heights for the shock mount, mono leaf plates mount the shock lower because the mono spring is thinner.
One thing you can't do is add multi leafs then use the mono leaf lower plate. The plate is moved downward by the thicker spring pack and the shock is not long enough to reach. This is why people think mono leaf shocks are shorter. You can add a drag race screw on shock extender to the top of the shock to make the mono plate work. This is a pretty common fix.
Another problem is on 67 Camaros, the 68 plates won't fit.
davidpozzi is offline
post #11 of 21 (permalink) Old May 14th, 07, 11:03 AM Thread Starter
bigsteve
My car is using multi leaf springs with mono shocks and shock bracket plate. So this will need to be changed to multi leaf shock bracket to fik the problem, I have the monro rear multi leaf shocks that the guy that installed the multi leaf springs did not use he told me that the gabrial shocks were still good. Looks like he was full of it and could not get the multi shocks to work with the mono bracket? thanks Steve
bigsteve is offline
post #12 of 21 (permalink) Old May 14th, 07, 02:54 PM Thread Starter
bigsteve
Also when I change the shock plate should I mount & torque the new plate to the axel before the axel is under the car or leave it loose till the leaf springs are loose mounted to the front bracket and shackle than torque it all together? thanks Steve
bigsteve is offline
post #13 of 21 (permalink) Old May 14th, 07, 04:51 PM
Banned
The '69 mono plates should be studded so are fine!!
It's only the '67's that give us a problem b/c their plates are mirror's of each other so we can't rotate one plate and use it on both sides!!! Like your hands if you look close...........
They are left and right so two plates are used whereas the '68/'69 rotate one plate due to the front and rear staggered shock locations..
Now, changing questions here!!
Don't tighten anything down UNTIL it is on the ground and you have bounced her up and down several times!!
pdq67
post #14 of 21 (permalink) Old May 14th, 07, 06:05 PM Thread Starter
bigsteve
The mono plates that I have on my 69 are not studded they have the staggered shock mount but uses the metal bars that the shick base fits in between. Is thereaway to put a stud on this type? I was told that the mount area was to low due to the added leafs in the new springs? thanks Steve
bigsteve is offline
post #15 of 21 (permalink) Old May 14th, 07, 06:22 PM Thread Starter
bigsteve
Is there any mods that I need to do with the spring perch because the car originaly came with single leaf and now has multi leaf? thanks
bigsteve is offline
'67 rs mono leaf to multi leaf car sits to high! nojoke900 Camaro Tech 17 Aug 30th, 07 08:53 PM
'69 Camaro - rear 10 bolt swap question billscamaros Transmission & Driveline 10 Apr 25th, 07 01:18 PM
Multi leaf in mono leaf perches Myfirst 69SS Transmission & Driveline 15 Nov 29th, 06 04:45 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
