Original rally wheels and disk brakes - Team Camaro Tech
post #1 of 5 (permalink) Old May 14th, 07, 07:07 AM Thread Starter
Greg
I am running the original rally wheels on my car that did not work with the original disks that were offered with the car. Will the newer after market kits fit under these rims?
68 383, TH-350, 3.55 Eaton Posi, Holley SA 770, RPM Air Gap, World Sportsman II, ISKY Roller Cam
emperor91108 is offline
post #2 of 5 (permalink) Old May 14th, 07, 07:52 AM
Smile Re: Original rally wheels and disk brakes
Are you asking about the 14" SS wheels ? Or the 15" ralleye wheels ?
The 15" should be fine with stock discs and I've even heard some people using the 14's ! (Not sure, how)
Also this post is talking about the same thing. https://www.camaros.net/forums/showthread.php?t=108063
TJS69 is offline
post #3 of 5 (permalink) Old May 14th, 07, 08:28 AM
I ran 14 x 7 rallys with factory disc brakes without issue on my 69. That combination came on thousands of 69 SS Camaros. Unfortunately, I sold the wheels and didn't note the code. Not sure about 68's - didn't they use the 4 piston calipers? There could be a clearance problem with those calipers.
BPOS is offline
post #4 of 5 (permalink) Old May 14th, 07, 11:43 AM Thread Starter
Greg
Do the newer after market kits fit any better then the originals or do they all have the same fit issues?
post #5 of 5 (permalink) Old May 14th, 07, 12:16 PM
DjD
DjD's Avatar
There are too many aftermarket kits to generalize. Any Camaro in '69 could have come with front disc's and for conversation only the Z/28 came with 15" wheels. You shouldn't have a problem finding a 14" wheel front disc combo that works. From what the white book shows if you have a 14" rally wheel or a dog dish hubcap wheel, disc's should fit. Only the full hubcap wheels were not available with disc brake cars.
...Dennis
DjD is offline
front drum brakes and rallye wheels dwcamaro Wheels & Tires 1 Apr 21st, 07 06:05 PM
drum to disk brakes 67cam jim67 Brakes, Suspension & Steering 5 Nov 24th, 06 03:03 PM
67 disk brake rally wheel codes camarozbest Tag Team 4 Jun 11th, 06 01:05 PM
C4 setup with rally wheels joesx11 Wheels & Tires 6 Jun 5th, 04 11:03 PM
'67 rally wheels - What is "correct"? Vitriol Wheels & Tires 4 Nov 15th, 99 10:47 AM
