69 camaro coupe rear axel leaf spring perch - Team Camaro Tech
post #1 of 6 (permalink) Old May 15th, 07, 02:56 PM Thread Starter
bigsteve
Would like to know if the rear axel originaly had mono leaf and the rear axel is converted to multi 5 leaf would the spring perch need to be changed because of the original mono perch being shorter or would the bigger space not make a diffrence? thanks Steve
bigsteve is offline
post #2 of 6 (permalink) Old May 15th, 07, 05:09 PM
Banned
Re: 69 camaro coupe rear axel leaf spring perch
Steve,
I wouldn't worry about it BUT I would use "U"-bolts like I said earlier!!
My car has been that way since about 1970 or so fine!!
Definately put the little-bitty "T"-bolts in a can up on the shelf!!!!!!!!
pdq67
post #3 of 6 (permalink) Old May 15th, 07, 06:44 PM Thread Starter
bigsteve
I have the u bolts I guess since I have the rear out I should change out the shock plates to multi spring type and I should be good to go? thanks Steve
bigsteve is offline
post #4 of 6 (permalink) Old May 15th, 07, 07:01 PM Thread Starter
bigsteve
Also the set up I have uses 4 u bolts and no t bolts is this correct?
bigsteve is offline
post #5 of 6 (permalink) Old May 15th, 07, 07:44 PM
As david Pozzi noted on one of your other threads, a monoleaf perch doesn't have the center hole used to properly locate the through bolt in the center of most multi-leaf springs, so you should check to see if a plate has been added or if the springs have a flat top through bolt.
Four U-bolts is fine, better than OE if they are good quality. GM used four T-bolts on low performance cars, and one U-bolt/two T-bolts on high performance 1st gens.
Eric
Eric Kammerer is offline
post #6 of 6 (permalink) Old May 16th, 07, 02:08 AM Thread Starter
bigsteve
what is this plate, is it the one used in the detroit speed mono to multi leaf conversion kit? I took my springs off the axel yesterday, the 5 leaf springs do have a flat top through bolt with a nut on the bottom and there was no plate just the mounting pads were used on my car. Thanks for your time and help Steve
bigsteve is offline
Leaf spring perch distance Conehead Brakes, Suspension & Steering 8 Dec 12th, 14 06:48 AM
'69 Camaro - rear 10 bolt swap question billscamaros Transmission & Driveline 10 Apr 25th, 07 01:18 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
Please post pics of your cars' stance after new leaf springs poloz28 Brakes, Suspension & Steering 29 Mar 11th, 04 08:58 AM
5th Gen Camaro in 07? 69ProTouring Bench Racing 6 Sep 15th, 03 11:24 PM
