Need help with Speed Tech - Team Camaro Tech
post #1 of 5 (permalink) Old May 15th, 07, 10:39 PM Thread Starter
madmax87's Avatar
I bought this 69 Camaro subframe with these Speed Tech A arms already installed. Nothing is tight yet, has QA1 coilovers on it. My question is, does the arm look too close to the frame. There is no weight on the front end. If the front drops considerably with the engine installed, I think it would clear fine. It just seemed weird that it would hit if I tighten them up the way they are. It's like that on both sides.
madmax87 is offline
post #2 of 5 (permalink) Old May 16th, 07, 05:07 AM
Rick
Re: Need help with Speed Tech
I think you're OK. My car, with another brand of UCA was the same way with no motor but the additional weight I had good clearance.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #3 of 5 (permalink) Old Jun 12th, 07, 09:35 AM Thread Starter
madmax87's Avatar
Installed engine and I still have less than 1/64 clearance on the back side of the arm. Has anybody had to grind down the side of the frame in question? I called Speed Tech and he didn't think there would be an issue. Just seems awful close.
madmax87 is offline
post #4 of 5 (permalink) Old Jun 12th, 07, 09:54 AM
Well... you are going to need to install shims, to align it ??
That will pretty much take up the rest of the room.
... And yes... I have had to trim the rear to get them to fit on some chassis... but no too many.
chicane67 is offline
post #5 of 5 (permalink) Old Jun 12th, 07, 12:55 PM Thread Starter
madmax87's Avatar
Shims??? Just kidding. I actually installed the recommended shim starting gap by Speed Tech and it's still too close. Well off they come for some subframe grinding.
madmax87 is offline
Speed Tech Tie Rod Sleeves Issue? MickyT Brakes, Suspension & Steering 20 Mar 24th, 07 09:27 AM
Speed Tech lower A arms 67ptcamaro Brakes, Suspension & Steering 4 Aug 28th, 05 08:57 AM
Convertible shake at certain speed range faninc Convertibles 9 Aug 17th, 05 04:12 PM
What gearing to run with my stall? Luke805 Performance 23 Oct 15th, 02 04:22 AM
