Torque for radius rod - Team Camaro Tech
post #1 of 2 (permalink) Old May 16th, 07, 05:17 PM Thread Starter
Daral
Does anyone have the torque specs for the bolts that hold the radius rod? Mine is round if that matters.
Daral (67 RS/SS 350)
Daral is offline
post #2 of 2 (permalink) Old May 17th, 07, 05:49 AM Thread Starter
Daral
Re: Torque for radius rod
OK, I have looked everywhere. Pozzi racing doesn't have it listed. I even have the Dealer Service Technical Bulletin 67-T-30 for "Radius Rod Installation" (Thanks Daniel). It lists all the parts and describes the installation but doesn't give any torque specs. If no one has this, I guess I will torque it to 50 ft lbs; the same as the rear spring shackles. I have torqued the bolt and nuts for the mounting plate to 25 ft lbs; the same as the bracket for the leaf spring perch. Does that sound reasonable?
Daral is offline
Comp Cams XE274H-10 Chris-in-Cali Performance 26 Aug 26th, 07 03:57 PM
rod bolt torque ctrghtous Engine 7 Sep 30th, 06 11:02 PM
Rod bolt torque rodek Performance 6 Mar 30th, 06 11:30 AM
350 rods 400 block? zachs camaro Performance 10 Aug 19th, 05 08:12 AM
ARP SBC Con Rod torque specs Rascal Engine 1 Apr 2nd, 05 10:36 PM
