Master Cylinder Question -C5 Brakes - Team Camaro Tech
post #1 of 2 (permalink) Old May 16th, 07, 09:45 PM Thread Starter
Hey guys, new to the forum, it's a great help. I have a '67 camaro I am putting 4 wheel disc brakes on. I am using C5 corvette calipers up front and 12" brakes from a '00 camaro in the back. Is there a master cylinder that will work with this setup and bolt to my stock 9" power booster? I am trying to avoid a complete and $$$ aftermarket setup. Thanks!
fierrogt is offline
post #2 of 2 (permalink) Old May 16th, 07, 10:34 PM
madmax87's Avatar
Re: Master Cylinder Question -C5 Brakes
I just talked with Touring Classic today about the same thing except I'm using there rear setup. He said any 1" bore master cylinder should work with no issues. He did recommend the shallow rod type MC compared to the long rod one. I told him I had a combination valve made for disk-drum and he said to try it and if it didn't work to install a manual proportioning valve for the rear.
madmax87 is offline
What master cylinder do I need? KC406RS Brakes, Suspension & Steering 8 Nov 19th, 06 07:31 AM
Master Cylinder for Disc Brakes? ItDoRun Brakes, Suspension & Steering 3 Aug 22nd, 05 09:35 PM
S-10 Quick Take Up Master Cylinder Question 72SSAbody Brakes, Suspension & Steering 10 Dec 20th, 04 03:30 PM
Help! what is this master cylinder and which one should i use on C5 brakes? cody Brakes, Suspension & Steering 5 Mar 12th, 04 08:07 PM
Master cylinder question x44d80 Brakes, Suspension & Steering 2 Feb 25th, 04 02:23 PM
