Rear Shock Length - Team Camaro Tech
post #1 of 3 (permalink) Old May 17th, 07, 05:31 AM Thread Starter
Rear Shock Length
I have installed new rear leaf springs from Eaton. I ordered them with 1 inch of extra arch as I like a litte "rake" as opposed to the in the weeds "PT" look.
I also installed a set of Competition Engineering slapper bars.
With the suspension loaded the lower shock mounting studs are about 1" above the mounting hole in the slapper bar.
Questions:
1.0 Are longer than stock shocks available? -or-
2.0 Should I use shock extensions? -or-
3.0 Should I use stock length shocks and fabricate a lower shock adapter that bolts to the Competion Engineering slapper bar?
As always thanks for the input.
The Yenko picture attached is the stance I am going for and those TTO's are killer!
Name:	Slappers & Springs 3.jpg
ID:	3261   Click image for larger version
Name:	Slappers & Springs 2.jpg
ID:	3262   Click image for larger version
Name:	Slappers & Springs 1.jpg
Name:	69 Yenko 2.jpg
69OlympicGoldSS is offline
post #2 of 3 (permalink) Old May 17th, 07, 09:25 AM
Codi's Avatar
Re: Rear Shock Length
You should be able to bolt up the original shocks. The 1" extension should be no problem. Or are the shocks fully extended and you still have 1"?
Daddy's Hot Rod.
Codi is offline
post #3 of 3 (permalink) Old May 17th, 07, 03:41 PM Thread Starter
Weight of car is on rear suspension. Passenger side shock is almost long enough, drivers side is about 1/2" short.
But even if they were just barely long enough there should be some additional extension, to keep from damaging the shocks, correct?
Keep in mind the leaf springs are brand new, 0 miles, and haven't "settled".
shock length aars Brakes, Suspension & Steering 1 Sep 18th, 06 03:16 PM
Should I chuck the traction bars? Car nut Brakes, Suspension & Steering 4 Jan 31st, 06 06:23 PM
Length of rear shackle bolts?? spideynut Brakes, Suspension & Steering 3 Aug 30th, 05 08:33 PM
To David - Rear Shock Geometry Q. James67RS Brakes, Suspension & Steering 6 Sep 17th, 01 03:44 PM
Rear Shock Towers and Mounts treyman Tech 2000 6 Aug 4th, 00 10:18 AM
