Upper Ball joint ???'s - Team Camaro Tech
post #1 of 23 (permalink) Old May 13th, 08, 09:40 PM Thread Starter
I'm replacing my upper ball joints on a 69 using cheapo replacements from Rick's. I've already replaced all the other parts in their kit or else I would send it back. I don't have any directions for the Upper ball joints. After many searches here and going to David Pozzi's site, it looks like they go in from the top of the control arm. It also appears that the boot and sleeve for the boot go on the ball joint and slide down from the top. Is this correct? It doesn't seem that the boot and sleeve will go on adequately to slide the whole thing thru the top. I tried installing it with the boot and sleeve on the bottom of the control arm, but it seems like the ball joint doesn't rest evenly on the control arm so it "torqued" or bent as I tightened the bolts. Help!
Another question: since I have no instructions, I don't know how much to torque the bolts. Some places say 20-25lbs (one of my bolts broke at 23lbs) another place said 15lbs.
I'm about ready to go buy Moog's and throw these away.
Thanks in advance,
Rookobird is offline
post #2 of 23 (permalink) Old May 14th, 08, 12:04 AM
CDJr
Re: Upper Ball joint ???'s
Yes, they go through from the top. As far as the torque, Id go by feel...youll know when theyre tight enough
CDJr is offline
post #3 of 23 (permalink) Old May 14th, 08, 04:39 AM
Nicholas
Send a message via AIM to dipren443
Thanks in advance,
John,
You have a PM.
Nick
Nick DiPrenda
Mechanical Design Engineer
1973 Camaro Z/28 Type LT
dipren443 is offline
post #4 of 23 (permalink) Old May 14th, 08, 05:33 AM
Bob
MileHigh69's Avatar
If you want to improve your steering geometry buy some Howe extended upper ball joints.
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #5 of 23 (permalink) Old May 14th, 08, 07:00 AM Thread Starter
Bob,
How do the extended ball joints improve suspension geometry?
Where do you get them?
Thanks,
post #6 of 23 (permalink) Old May 14th, 08, 07:09 AM
Nicholas
Bob,
Thanks,
http://www.scandc.com/balljoints.htm
Helps in several areas. Optimizes Camber curve, increases static negative camber slightly.
Nick DiPrenda
post #7 of 23 (permalink) Old Feb 25th, 16, 07:58 AM
Jason
Gambitt's Avatar
Send a message via MSN to Gambitt
Is there any updated information on where to get the Howe extended upper ball joints? The link above appears to be dead. Thanks!
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #8 of 23 (permalink) Old Feb 25th, 16, 08:04 AM
Jason
Gambitt's Avatar
I found it. So these are $80 each? More than I was expecting.
http://www.howeracing.com/p-7926-how...its-k5108.aspx
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #9 of 23 (permalink) Old Feb 25th, 16, 09:37 AM
Jeff
yellow69RS's Avatar
The upper ball joints I've used go in from the top and the boot and retainer go on the bottom. If you have no retainer (secured by the bolts/rivets) you will need to tap the boot on from the bottom with a socket or pipe. All of the lowers I've seen are like that
Jeff
yellow69RS is offline
post #10 of 23 (permalink) Old Feb 25th, 16, 11:31 AM
Jason
Gambitt's Avatar
I revived an old thread, I guess I should have started a new one. Has anyone used these extended upper ball joints? Are they $80 each? I'm not sure it they are $80 each or $80 for 2 upper ball joints. Thanks.
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #11 of 23 (permalink) Old Feb 25th, 16, 03:51 PM
Pretty sure it's each.
here's another option https://www.suspension.com/products/...all-ball-joint
BPOS is offline
post #12 of 23 (permalink) Old Feb 25th, 16, 06:26 PM
Andrew
Andrew69's Avatar
I put the Proforged on my car with the Guldstrand mod. I believe Proforge now offers an even taller ball joint. https://www.camaros.net/forums/showth...ll+ball+joints
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #13 of 23 (permalink) Old Feb 25th, 16, 06:56 PM
Jason
Gambitt's Avatar
Those prices are killing me!
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #14 of 23 (permalink) Old Feb 25th, 16, 07:09 PM
Doug
These are the ball joints I use on my Camaro along with Global West tubular control arms with Del-A-Lum bushings. They are $50 dollars each. http://www.summitracing.com/parts/po...t/model/camaro Here is a link to the installation instructions for Moog upper ball joints with pictures. http://www.moogproblemsolver.com/moo...s/AXCF3616.pdf
Cdminter55 is offline
post #15 of 23 (permalink) Old Feb 26th, 16, 05:45 AM
Jason
Gambitt's Avatar
$50 each is better. I wish I had not have purchased the stock-type Moog ball joint now, but I didn't find out about this until after I placed the order.
Thanks for the help everyone!
Gambit
69 RS/Z28
Pics:
Gambitt is offline
