Steering Wheel Off Center - Team Camaro Tech
post #1 of 5 (permalink) Old May 19th, 08, 08:25 AM Thread Starter
J
I've removed my steering wheel a number of times along with the lock plate to get my horn to work and I never ran into this problem. I put everthing back together the same way and now my steering wheel is off center to the left. I'm thinking I counter by moving the horn tower and lock plate to the right to help comphensate? Not sure I can do this. Do I need to get the can aligned?
Any advise would be greatly appreciated.
Thanks!
jkkrs310 is offline
post #2 of 5 (permalink) Old May 19th, 08, 01:23 PM
Greg
Re: Steering Wheel Off Center
The alignment marks should line up - on the steering wheel and on the steering hub - to do it right the right way.
If the marks are already lined up, and wheel off center, time for a front end alignment
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #3 of 5 (permalink) Old May 19th, 08, 04:40 PM Thread Starter
J
Greg
Can you expand on the marks. Obviously I've been removing without knowing about these marks.
Thanks!
jkkrs310 is offline
post #4 of 5 (permalink) Old May 19th, 08, 07:04 PM
Greg
If you look on the steering shaft, and steering wheel, you will see vertically etched marks that should line up if the steering wheel is sitting in the correct notch/groove.
1969 RS/SS Vert
chops is offline
post #5 of 5 (permalink) Old May 19th, 08, 11:15 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Although if the column was ever rebuilt by the @#[email protected]# @#[email protected] that Rick's bought their rebuilt columns from, the chisel mark in the shaft will point the wrong direction and won't line up anymore.
Here are full instructions for properly centering a steering wheel: http://jimshea.corvettefaq.com/wp-co...Rev18MY062.doc
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
