69 porportioning valve question - Team Camaro Tech
post #1 of 7 (permalink) Old May 20th, 08, 09:05 AM Thread Starter
Greg
Send a message via AIM to duckbutter69
The round valve below the booster is leaking out of the back where the dust cover is. Anyone take one of these apart? Is it an O ring or will I need to replace the whole unit? If I need to replace it does anyone know where I can pick one up new?
Thanks,
Greg
69 Convertable
427, TKO, 9"
duckbutter69 is offline
post #2 of 7 (permalink) Old May 21st, 08, 11:12 PM
Ray P.
camaro_fever68's Avatar
Re: 69 porportioning valve question
Is this what you are referring to?
http://cgi.ebay.com/ebaymotors/69-No...spagenameZWDVW
Ray
camaro_fever68 is offline
post #3 of 7 (permalink) Old May 22nd, 08, 12:10 AM
I'm sure they are rebuildable. I've never had the 67-69 valve apart, but I have had the 70 and later valves apart. A couple of O rings seals the things up. I imagine you can pick them up at NAPA or some place like that. Just make sure you get O rings for brake fluid, as it may eat up a standard O ring.
buenymayor is offline
post #4 of 7 (permalink) Old May 22nd, 08, 06:06 AM
Heartbeat City sells the rebuild kit for your valve. The seal that is leaking is a flat o-ring, I don't think a regular o-ring will fit properly in the groove. Mine had a slight leak. I took it apart and found the seals to look good but there was a slight build-up on the shaft where it seals. I used fine steel wool to polish the shaft and reassembled. The valve is woking fine with no leaks.
Greg
69 Z28
maizedog is offline
post #5 of 7 (permalink) Old May 22nd, 08, 07:37 AM
"Tri-Tip"
Gary L's Avatar
Karp's Brake in the Los Angeles area will do it for $65.
Gary L is offline
post #6 of 7 (permalink) Old May 22nd, 08, 09:31 AM Thread Starter
Greg
Thanks guys. From the description on ebay - The valve is mounted off the stud of the master cylinder and holds off pressure so the rear drums will kick on a second before the front disc's. The fluid builds up pressure and once it by passes the spring in the valve it applies pressure to the front brakes. - it looks like I dont even need it. I've changed my rear drums to disc and have plumbed in a porportioning valve.
Greg
69 Convertable
427, TKO, 9"
post #7 of 7 (permalink) Old May 22nd, 08, 12:49 PM
Ray P.
You are correct that you don't need it with disc brakes. A proportioning valve is all that is needed. That is how my disc/disc is setup.
Ray
