pitman arm: worn out? - Team Camaro Tech
post #1 of 6 (permalink) Old May 20th, 08, 02:53 PM Thread Starter
I just removed my original pitman arm from a 68 with Power steering. I can wiggle the stud of the pitman arm just a little.....does that mean its worn out? Thx.
esahlin is offline
post #2 of 6 (permalink) Old May 20th, 08, 04:10 PM
Banned
Re: pitman arm: worn out?
Hard to wiggle it??
Probably fine.
If it's sloppy like a worn out ball-joint, can it!
pdq67
post #3 of 6 (permalink) Old May 20th, 08, 05:39 PM Thread Starter
The wiggle is hardly measurable I would say....less than 1/16 of an inch movement if I move it side to side.
esahlin is offline
post #4 of 6 (permalink) Old May 20th, 08, 06:18 PM
It shouldn't move at all from side to side. I'd replace it as it will move more under load.
go2fast is offline
post #5 of 6 (permalink) Old May 20th, 08, 06:47 PM
I would also replace it. It's been under there for 40 years most likely.
To me, any movement is too much for any front end joint.
post #6 of 6 (permalink) Old May 21st, 08, 07:48 PM
Banned
Right b/c I meant almost no movement and tight to boot!
pdq67
