my car sits up to high in the front and the rear - Team Camaro Tech
post #1 of 4 (permalink) Old May 26th, 08, 08:04 AM Thread Starter
bunk
I have a 69 with new springs and shocks all the way around .How long will it take for them to sit down a lil bit
bunkyyy69 is offline
post #2 of 4 (permalink) Old May 26th, 08, 08:31 AM
Skip
Skeeter55's Avatar
Re: my car sits up to high in the front and the rear
What kind of springs. And did you or the mechanic torque the bolts down with the weight of the car on the ground.
Can you show some pictures.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 4 (permalink) Old May 26th, 08, 10:36 AM
Bill
I installed Hotchkis TVS with front and rear springs and sway bars and it does not seem any lower. I would not say that it looks too high but it did not seem to lower. It was installed and tightened with jack stands under frame rails. Should I put it back up with stands under rear axle and front a-arms to load them like they are on the ground and loosen/re-tighten ? If so, what bolts would cause a change ?
67 - Coupe - Bahama Blue, 427 SBC, TKO 600, Hotchkis TVS, Eaton Posi / 4.11
WV6TY7 is offline
post #4 of 4 (permalink) Old May 26th, 08, 10:40 AM
Skip
Skeeter55's Avatar
Most definitely. The A-arms and shackles also the sway bars.
