95 Camaro Suspension Question - Team Camaro Tech
post #1 of 3 (permalink) Old May 26th, 08, 10:29 PM Thread Starter
Have a 95 Z28, that's pretty squeaky from the rear. I think it's the rear suspension bushings, but I'm not sure what to do about it.
I think it will be easier to buy something like this:
http://www.lmperformance.com/4346/17.html
But I can't find any reviews of it. Has anyone used it? Is it ok to replace the rear arms and not the fronts?
Hotchkis Lower Control Arms
muffin_man is offline
post #2 of 3 (permalink) Old May 26th, 08, 11:08 PM
Re: 95 Camaro Suspension Question
unless it's already got poly bushings in it, i don't think it's the bushings.
i think there are rubber spring isolators that go between the spring and body- if they are gone, then it might squeak like that.
it's also possible that your exhaust is rubbing something- either the torque arm or panhard bar would be a good place to look.
you don't plan sincerity.
novaderrik is offline
post #3 of 3 (permalink) Old May 26th, 08, 11:55 PM
It's most likely the sway bar bushings. It's a really common problem on 4th gens to have them squeak. Not much you can do about it aside from grease them every few weeks.
1967 Camaro - LM7, T56, TVS
1996 Impala SS - DD
Acidburn is offline
