Polygraphite Pst Bushings - Team Camaro Tech
post #1 of 16 (permalink) Old May 30th, 08, 07:37 AM Thread Starter
Ray
Hello.
I recently purchased a suspension upgrade kit from PST for my tired Camaro. I have to admit that I am a bit concerned now by the split reveiws I have read concerning noise ( Squeaks ).
I am very interested in hearing from those who have had positive results with the POLYGRAPHITE components and process used to install. I am going to give these bushings a try and want to use an installation process that results in a positive outcome.
I have read it relies on proper lubing of components.
I also wonder what is an acceptable lubricant for these bushings.
Has anyone used Marine Lube ?
Thanks for reading and comments.
Ray
Raysdz is offline
post #2 of 16 (permalink) Old May 30th, 08, 08:15 AM
Jon
Re: Polygraphite Pst Bushings
I just installed prothane poly's in the rear suspensions in my car. As for the lube, I couldn't find a comparable grease to the stuff they sent. I know others have said to just use a silicon based grease, but the stuff from them was extremely "sticky", so I purchased extra grease packets from Prothane.
JD4020 is offline
post #3 of 16 (permalink) Old May 30th, 08, 09:37 AM
I guess it depends on which bushings are poly. I just rebuilt my front and back and based on recommendations, used all poly except the upper & lower control arm bushings which are still rubber. No complaints about squeaking or handling.
1970 original owner, F41
bowtie-70 is offline
post #4 of 16 (permalink) Old May 30th, 08, 09:43 AM
Daral
Summit carries this lube. It is called Super Grease (PTP-19-1751). I bought some so I could use plenty when I installed the prothane poly bushings front and rear.
Daral (67 RS/SS 350)
Daral is offline
post #5 of 16 (permalink) Old May 30th, 08, 10:32 AM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
I've had PST polygraphites on my control arms since '99. I haven't had problems with squeeking, but I don't really have than many miles on them (under 10,000miles). I have noticed that the upper bushings look like they have flowed a bit. Since joining this forum, I've read quite a few people say to go either rubber or Delrin because poly binds too much.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #6 of 16 (permalink) Old May 30th, 08, 08:56 PM
Send a message via AIM to RamAirDave
Ive put the Polygraphite in probably a handful of cars, not a squeak out of any of them.
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #7 of 16 (permalink) Old May 31st, 08, 04:07 AM
Banned
Isn't this why they add graphite to the poly so it stops squeaks??
pdq67
post #8 of 16 (permalink) Old May 31st, 08, 05:01 AM
1st 67 SS/RS's Avatar
I put the PST (polygraphite) full front end rebuild kit and the body mounts on over a year ago and put close to 1000 miles on the car with no squeaks. No problems, I used the grease they sent. I haven't regreased the fittings yet. The car is street use only.
67 Vert RS/SS 350 4 SP
1st 67 SS/RS is offline
post #9 of 16 (permalink) Old Jun 2nd, 08, 01:03 PM
Bill
I've got these type bushings just about everywhere on the car and no squeaks. It is good idea to get some more lube cause they don't give you enough w/the kit.
68RS-SS is offline
post #10 of 16 (permalink) Old Apr 7th, 09, 03:27 PM
Kevin
I guess I'm getting confused after reading all this.
Polyurethane components (energy suspension co.) need to be greased up. (?)
Polygraphite components (PST co.) have graphite impregnated in them so they dont need to be greased. (?)
69Rook is offline
post #11 of 16 (permalink) Old Apr 7th, 09, 03:59 PM
Fred
77thor's Avatar
They both need to be greased, very liberally. But Polygraphite is less likely to ever squeak.
I put those PST Polygraphite ones in my 77 Camaro.... 6 years without a squeak... sold the car last year.
77thor is offline
post #12 of 16 (permalink) Old Apr 7th, 09, 06:27 PM
Arch Stanton's Avatar
I finished my front suspension project recently.
Used Energy Suspensions black/polygraphite bushings. Also bought an extra little thing of their lube.
Used the lube liberally on installation, followed the directions exactly.
Not a sound.
- John
Misfit tortured soul. Lone wolf. Unicorn.
'67 V8 Camaro - 12637, 797-Z (Parchment), M-M (Royal Plum), 2M, 3K, 5Y
Arch Stanton is offline
post #13 of 16 (permalink) Old Apr 8th, 09, 05:07 PM
Jeoffery J
Het guys what is the differance in ride quality?? My car is street only, is it much harsher then rubber?
Jeoff J.
Buffalo , NY...Brrrr
MY RIDE:
project "semi precious metal"
chuckboy7 is offline
post #14 of 16 (permalink) Old Apr 8th, 09, 05:45 PM
Not really harsher at all, just seemed to make it feel more "solid and pointed to where you steered it", but then, replacing the old worn out bushings with new ones, I'm sure any type of new bushing will make it feel better.
Hard to describe......
- John
post #15 of 16 (permalink) Old Apr 8th, 09, 08:01 PM
Banned
I figure THE BEST will be STEEL on STEEL bushings/kingpins and zerks w/ moly gun-grease every oil change!
The old cars used to be made this way, BUT people were too stupid to grease them!
pdq67
