Breake bleeding help needed - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 3rd, 08, 01:04 PM Thread Starter
Let me tell you what I have first off, its non power master cylinder, c5 corvette calipers in front, c4 calipers in back, lines and proportioning/distribution block are from "The right stuff" outa Ohio.
Problem: Im trying to bleed the brakes and im not getting anything.Pumping the brakes doesnt do anything. I got a craftsman vacumn pump and all I can get is a little dribble out of the fronts, nuthing out of the rear, and thats with 5 to 10 inches of vacum. I bench bleeded the master it seemed to be working ok. I even disconected the brake line in back to see if i could get it to gravity feed and 3 hours later nuthing. If anyone has a suggestion please let me know.
JBs69conv is offline
post #2 of 4 (permalink) Old Jun 3rd, 08, 01:43 PM
TC
Re: Breake bleeding help needed
Are you doing this with the cap off? Try and do it with someone puching the pedal to check or go to a feed store and get a large suringe and fill it and back bleed it from the bleed hole under pressure. This is acually the best way since it pushes the air upwards to the resivoir where you want it to come out.
6Z8RS is offline
post #3 of 4 (permalink) Old Jun 3rd, 08, 01:47 PM
I thought I was going CRAZY when I tried to bleed mine after changing all the rear lines.
Make sure the master is fully bench bled. Long slow stokes. No bubbles. I always do lots of extras just to make sure.
Make sure the lid is off the MC. Start with gravity, then pressure bleed from the farthest to the closest away from the MC.
I've heard one problem with the vaccum bleeders is they'll suck air around the bleed screws.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is online now
post #4 of 4 (permalink) Old Jun 3rd, 08, 02:38 PM Thread Starter
Thanks for the suggestions guys, but I think I found my problem, I took the rear line off the proportioning/distribution valve and tried pumping it, got nuthing, so I hooked up the vacumn pump to that and started getting fluid, so I think that valve needed bench bled also. Has anyone else had this problem?
While it was unhooked I hooked a hose to the line then put it in a full bottle of brake fluid and used the vacumn pump at the caliper to prime the entire rear brake line
Now that im getting fluid to the rear brakes i discovered a leak at the rear caliper, looks like the copper washer got gouged by a little peice of flashing on the caliper. yay if it aint one thing its another.
BTW: sorry about the poor spelling on the thread title, i was pulling my hair out at the time.
