68 spring diameter? - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 4th, 08, 10:52 AM Thread Starter
Andrew
68 spring diameter?
Urgent help needed. Can anyone confirm inside/outside diameter of 68/69 front springs? Trying to order some global west alloy spacers but they say 4inch outside for usual 1103 spacer? My springs are 4inch INSIDE, around 51/4 outer dia.Not sure if they are originals but seem to fit seat pockets ok. Cant find spring info or spacer dims.
540 camaro is offline
post #2 of 6 (permalink) Old Jun 5th, 08, 06:04 PM
Banned
Re: 68 spring diameter?
A 307 engine Sport Coupe car regular # 6314 spring w/o A/C should be 3.675" ID and like 4.895" OD. from my 1996 CarQuest Spring Cat.
A #638 396 Coupe car's w/o A/C spring is 3.625" ID and 4.885" OD.
I have shortened # 5536's in my car that started at 488 pounds and I figure are right at 525 pounds.
pdq67
post #3 of 6 (permalink) Old Jun 5th, 08, 10:10 PM
David Pozzi
davidpozzi's Avatar
First gen coils are called 5" OD, but they actually will measure a bit larger. second gen coils are 5.5" OD, but will also measure a bit larger if the wire is thicker.
davidpozzi is offline
post #4 of 6 (permalink) Old Jun 6th, 08, 01:02 AM Thread Starter
Andrew
Thanks for reply, reason i,m confused is GW say 1103 is 1st gen but insist is 4" OD (rang twice) also on jegs listed as 4"OD? Has anyone used 1103 spacer with 5" od gen1 spring?? really confused & need to order this week.
post #5 of 6 (permalink) Old Jun 10th, 08, 06:31 AM
JC
68inwork's Avatar
Anyone know what the height of a stock coil is supposed to be out of the car?
68inwork is offline
post #6 of 6 (permalink) Old Jun 10th, 08, 06:53 AM
Andrew - 1103 is the spacer that CFunk used on his 67, and what I bought for my 69. I have not had a chance to put them in yet. https://www.camaros.net/forums/showth...highlight=1103
http://www.funkconsulting.com/67cama...acer/index.htm
JC - the free height depends on the spring's application and construction. If you're trying to figure out what you have, we need to know more info like how the car was equipped from the factory (A/C, HD suspension, big block or small block, etc.). If the coils are replacements (like Moog, for example), you may find a part number stamped into the end coil.
Eric
Eric Kammerer is offline
