brake capacity - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 10th, 08, 08:32 AM Thread Starter
Trev
madcarson's Avatar
brake capacity
anyone know about how much fluid it takes to fill new complete frt to back disc/disc system 69 camaro ? I'm going to use DOT5 and NAPA only has it in 350 ml jugs!
madcarson is offline
post #2 of 3 (permalink) Old Jun 10th, 08, 12:49 PM
Matt
Re: brake capacity
I used one and a half of the 32-ounce containers for my new disc/disc install.
Are you sure you want DOT5? Most here do not recommend DOT5. Have you read some of the posts about DOT3, 4 and 5. If not, I recommend you do a search.
Good luck.
Matt M. is offline
post #3 of 3 (permalink) Old Jun 10th, 08, 11:49 PM
Re: brake capacity
yeah, I used dot 5 and wish I didn't.
not only is it about 4x as expensive but its holds air bubbles and any water in the system will settle in the lowest point and want to rust out
400bird is offline
