New Rear Leafs? - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 14th, 08, 07:52 AM Thread Starter
New Rear Leafs?
For David Pozzi or anyone who knows...I have 5 leaf springs on my 69 350SS coupe with PS, PB, AC, 4sp. As I am restoring all aspects of this car, I put Moog 6308 in the front and Pozzi recommends 175lb spring rate for the rears. Where do I get rear leafs with this rate? What would be the rate of my 40 year old 5 leaf springs?
Thanks in advance,
Rookobird is offline
post #2 of 8 (permalink) Old Jun 14th, 08, 12:35 PM
Banned
Re: New Rear Leafs?
Probably around 135 or so??
Just a guess tho..
pdq67
post #3 of 8 (permalink) Old Jun 16th, 08, 07:48 AM Thread Starter
Re: New Rear Leafs?
Where to get new ones ? 175lbs.?
Thanks,
post #4 of 8 (permalink) Old Jun 16th, 08, 03:47 PM
Banned
Re: New Rear Leafs?
Eaton Spring can make you up a set, just make sure you get to the one that does b/c there's two of them.
They have ALL GM's spec's b/c they made them way back then.
pdq67
post #5 of 8 (permalink) Old Jun 21st, 08, 07:20 AM Thread Starter
Re: New Rear Leafs?
I can try Eaton- I'm not sure what you mean, pdq, to get the right one- there are two.
Are there two Eaton's or two springs?
There's nowhere we can just buy 175lb spring rate multi leaf springs- off the shelf?
I was hoping David would chime in since he recommends them with 6308's up front.
Thanks,
post #6 of 8 (permalink) Old Jun 21st, 08, 08:50 AM
Banned
Re: New Rear Leafs?
Here's the one you want to contact, Detroit Eaton Spring.
http://www.eatonsprings.com/
Ask them if they can create a stock ride height 175 pound rated leaf spring for your application.
And Here is the other one..
http://www.eaton.com/EatonCom/OurCom...tory/index.htm
And if nobody will fix you up, then hunt up "Chicane" on the sites and ask him if he wants to help you get a pair like you want?
Tell Chicane, that ol' pdq67 sent you asking..
pdq67
PS., and you might want to go over to Larry C's great Pro-Touring site and ask the guys over there!
http://www.pro-touring.com/forum/
And say hello to Larry for me too!!
post #7 of 8 (permalink) Old Jun 21st, 08, 04:16 PM
Re: New Rear Leafs?
Thanks,
There is nowhere that you could buy stock looking, stock height springs at a specified rate right off the shelf. Eaton should be able to make ones for you.
You could get lowering springs about that rate, but most lowering springs are 3 leaf it seems.
400bird is offline
post #8 of 8 (permalink) Old Jun 22nd, 08, 09:39 AM
Banned
Re: New Rear Leafs?
Two Eatons, please re-read my prior post.
pdq67
