67 Steering column - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 17th, 08, 03:56 PM Thread Starter
67 Steering column
Hi All,
Hope im in the right area, i pulled out my steering column not too long ago during the resto, and three small springs fell out. What do these do? are they important? do i need to get it rebuilt or should it be ok to drive still?
Any help is good help, thanks in advance.
Dan.
67 RS/SS 4 speed... YEE HAR!
dan6t7 is offline
post #2 of 5 (permalink) Old Jun 17th, 08, 06:17 PM
Re: 67 Steering column
Dan- Here is a link to part of the assembly diagram of the column. See if it helps you find out what springs that fell out and see if you can figure out where they go.
http://thefirstgensite.com/library/6.../steering.html
esahlin is offline
post #3 of 5 (permalink) Old Jun 17th, 08, 07:15 PM Thread Starter
Esahlin, Im having trouble getting the link to work, i got onto the firstgen site can only locate firebird steering column i assume its the same?
Cheers,
Dan.
dan6t7 is offline
post #4 of 5 (permalink) Old Jun 17th, 08, 08:35 PM
You didn't mention if the springs were coil springs or leaf type springs.
If they are coil springs I believe they are the ones between the housing and the lock plate. The go around the three screws. A lot of people make the mistake in removing the three screws before they remove the housing from the column. You loosen the three screws and then rotate the whole assembly (sort of a cam lock) and the whole thing comes out of the steering column.
JIML82 is offline
post #5 of 5 (permalink) Old Jun 19th, 08, 08:15 PM
Sorry about the link. Yeah, Firebird is the same as Camaro column.
esahlin is offline
