how a raise my front end - Team Camaro Tech
post #1 of 15 (permalink) Old Jun 18th, 08, 05:38 PM Thread Starter
Arrow how a raise my front end
i want to raise my front end about 2 inch any ideas? also what the new thing they got for cars? look like a lift kit. they lift it about 6 to 8 inchs
camaro9 is offline
post #2 of 15 (permalink) Old Jun 18th, 08, 07:04 PM
Re: how a raise my front end
Two inches higher than stock? Or two inches higher than slammed, saggy springs?
You will have to be a little more specific about "the new thing" like a lift kit...
400bird is offline
post #3 of 15 (permalink) Old Jun 18th, 08, 07:50 PM
Ryan
Also, has your car had an engine swap from a 6 cyl to a small block, or a small block to a big block?
Rhino is offline
post #4 of 15 (permalink) Old Jun 19th, 08, 05:04 PM Thread Starter
two inchs higher i have ne coil springs i put 15 inch tires on it it a 1969 camaro 350 engine
camaro9 is offline
post #5 of 15 (permalink) Old Jun 19th, 08, 05:49 PM Thread Starter
Lightbulb Re: how a raise my front end
i see some these car lift up in the front and rear it look like a lift kit for cars i was wondering if i could do that to my 1969 camaro front only
i put 15 inch tires on it it had 14 inchs any ideas?
camaro9 is offline
post #6 of 15 (permalink) Old Jun 19th, 08, 05:50 PM Thread Starter
know engine swap
camaro9 is offline
post #7 of 15 (permalink) Old Jun 20th, 08, 07:58 PM
Can you post a picture of your car?
You can try a company called Detroit Eaton Spring, http://www.eatonsprings.com/
Talk to them, they will make you any spring you want.
Raising a car 2" is not common at all because Camaros were fairly tall from the factory.
My guess is that you have a backspacing problem not a height problem. If the backspacing on your rims was correct you should not have a problem with your tires rubbing. 15 inch rims were a factory option and as long as you do not have huge tires on them , they should not be a problem.
400bird is offline
post #8 of 15 (permalink) Old Jun 21st, 08, 05:09 AM
Camaro9- i just have to ask.. is English your first language? i'm not trying to be mean, but i can't really figure out what you have and what you are trying to achieve.
are you having clearance issues due to larger tires, and just want to jack it up to get them to clear? if so, what wheels are you running- there are hundreds of different 15" wheel designs with different backspacing, and there are hundreds of different tires you could have on it ranging from skinny low profile tires to tall and wide 4X4 truck tires.
it might be as simple as getting different wheels and/or tires that actually fit the car.
if you just don't like the way it sits with the new wheels, then tell us exactly what you are trying to achieve (and show us with a couple of pics- everyone knows someone with a digital camera or cell phone with a camera).
you don't plan sincerity.
novaderrik is offline
post #9 of 15 (permalink) Old Jun 21st, 08, 05:16 AM
Andrew
Andrew69's Avatar
Maybe the car has 2" drop spindles on it already??? We have to know where you are before we help you get where you want to go.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #10 of 15 (permalink) Old Jun 21st, 08, 05:41 AM
Jerry R.
jr68's Avatar
Maybe he is going for the retro look
in the 60's they would ride high in the front end for a gasser look and back then it looked cool on a 55 or 63 Chevy or 67 Nova to compliment the huge rear tires.
But man I haven't seen that in a while
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #11 of 15 (permalink) Old Jun 21st, 08, 06:35 AM
Banned
Smile Re: how a raise my front end
My car was always up in the air w/ my SB on my BB A/C coil springs, (after I wore out my stock, D-70 wide-oval redlines and switched back to a shorter tire than the old 29.5" tall M&S's I used to run in the winter time)! Better to match my great big old L-60/14's in the rear!
Sucker looked down-right muscular!!
And I made my suspension so stiff front and rear that I could darn near skip sideways turning a 90 degree corner by kicking her out sideways using the throttle! Rode like a lumber wagon until I was at SPEED and WAY ABOVE!! He, He..........
And I'm talking about WAY ABOVE!!!!!!!!!!!!!!!
pdq67
post #12 of 15 (permalink) Old Jun 21st, 08, 08:08 AM
If you really want to raise the front, you can add coil spring spacers to it. You may want to lower rear. You can add lowering blocks between the spring and the axle.
TJS69 is offline
post #13 of 15 (permalink) Old Jun 21st, 08, 10:47 AM
Fred
This thread has me going through 45 years of memories. Whew!
128.79mph 1.428 60'
Fred Ficarra is offline
post #14 of 15 (permalink) Old Jul 2nd, 08, 05:03 PM Thread Starter
i have a 1969 camaro! it had 14 inch tires on it . i took the 14 inch off and replace them with 15 inch tires and wheels when turn it rubs the inside of the inner fender a little i try not turn turn to much! i want to rasie the front up about 1 to 2 inchs
camaro9 is offline
post #15 of 15 (permalink) Old Jul 3rd, 08, 04:37 PM Thread Starter
hi again
i took some pictures of my car but i do not know how to get them from here to you.
if you could help would be nice i put bigger coil springs on the front yesterday it the same what else can i do??????????
thanks
camaro9 is offline
