Strange noise and jerk when I turn - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 20th, 08, 07:11 AM Thread Starter
Joe
Joes67ss's Avatar
Every time I make a sharp turn I hear a loud klunking noise and from the front of the car.The car even jerks sometimes when I hear the noise...
The front side of the rim and tire were hit against a curb about a month ago..any ideas of what it could be?
Joes67ss is offline
post #2 of 7 (permalink) Old Jun 20th, 08, 07:30 AM
Joe
Re: Strange noise and jerk when I turn
Any visible signs of damage or rubbing under the car? Does it happen when you turn left or right or both directions? How does the car track...does it pull left or right while driving or braking?
Z282NV
1969 Camaro
Z282NV is offline
post #3 of 7 (permalink) Old Jun 20th, 08, 07:36 AM Thread Starter
Joe
Joes67ss's Avatar
No visable signs that I could see ...Car doesnt pull at all..It happens when I make a right turn tho...hope that helps
Joes67ss is offline
post #4 of 7 (permalink) Old Jun 20th, 08, 08:23 AM
Joe
Sounds to me like a bad tie rod end or even one of the ball joints. If it was a bent rim or even a wheel bearing you would feel that even when you are driving straight.
Z282NV
1969 Camaro
Z282NV is offline
post #5 of 7 (permalink) Old Jun 20th, 08, 09:37 AM Thread Starter
Joe
Joes67ss's Avatar
ok ill look into that..thanks for the help
Joes67ss is offline
post #6 of 7 (permalink) Old Jun 20th, 08, 02:55 PM
Dan
Also check your upper control arm alignment shims, I have had them come out before and your upper control arm will make a clunk sound.
68 camaro RS 327/275 THM350 4 wheel disc brake 8.5 10 bolt 3.42 daily driver
icpop is offline
post #7 of 7 (permalink) Old Jun 20th, 08, 06:25 PM
Tony
Check your rag joint. I had a torn one on my 68, and it would make a clunking sound upon hard turns.
tonycamaro is offline
