small hole in the frame the shape of a spade - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 26th, 08, 04:29 PM Thread Starter
Johnny
Does anyone have or seen a hole in the frame like this? what can cause this, tire rub? and how to go about fixing it? the same side up front of the frame has one also but none at all on the drivers side.
67Camaro 396BB 750Holley, edlebrock performer,280isky,3.42 posi, turbo 350,stage 2 shift kit, 2800 stall, MSDready to run distributor, headers, 2.5"exhaust, Hotchkis(1.5"/2"drop).(orig.Deep water blue/light blue dlx inter, v8 column shift/bench seat)
johnny67 is offline
post #2 of 2 (permalink) Old Jun 26th, 08, 05:49 PM
Steps
Re: small hole in the frame the shape of a spade
Fix.. turn the heat up on the mig, that will burn back any thin bad metal, then build up the holes and grind sand off.
Looks like a bit of wear in the rub marks too, I would ne checking thickness /strength there to.
Steptoe is offline
