low brake pressure - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 30th, 08, 01:13 PM Thread Starter
low brake pressure
Iíve been trying to bleed my brakes without success so I got a motive pressure bleeder and was able to get some pressure. The problem is it isnít much pressure; itís a 4-wheel disc setup with c4 calipers and a manual master cylinder.
When I bleed the brakes all I get is fluid no air bubbles, so I donít think its air in the system. But I canít seem to get good pressure. Any thoughts on what mite be wrong?
JBs69conv is offline
post #2 of 6 (permalink) Old Jun 30th, 08, 01:42 PM
Steps
Re: low brake pressure
Discs mounted with bleeds at the top?
Steptoe is offline
post #3 of 6 (permalink) Old Jun 30th, 08, 01:48 PM Thread Starter
The front caliper bleeder fittings are on top. The rear calipers fittings are on the side and centered on the caliper.
post #4 of 6 (permalink) Old Jun 30th, 08, 02:57 PM Thread Starter
Im wondering if a brake booster would help. Or could there be a problem with the MC, its a 1'' manual set up. Any sugestions?
post #5 of 6 (permalink) Old Jun 30th, 08, 08:20 PM
And if the bleeders are not on the top when mounted, you said the rears on centered, you will have to unbolt them and hold the calipers so the bleeder is the highest point. Then the air will rise and should exit via the bleeder.
Also it might be worth it to tap the master and calipers a few times while bleeding, they say air can stick to the side of the castings and a few taps with the handle of a screwdriver will knock them loose.
Did you bench bleed the master? Is the pushrod adjusted correctly?
400bird is offline
post #6 of 6 (permalink) Old Jun 30th, 08, 08:28 PM Thread Starter
Im gonna try adjusting the pushrod some tomorow, and ill try tilting the rears to. im so outa ideas on what could be the problem.
I did bench bleed the master, and tapped on the calipers and mc.
