pulling to the right - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 30th, 08, 01:59 PM Thread Starter
RICK
90 camaro , front brakes pulling to the right , brakes and rotors look fine .
RICS71 is offline
post #2 of 5 (permalink) Old Jun 30th, 08, 02:17 PM
ZZ_430's Avatar
Re: pulling to the right
Make sure the calipers slide freely on the pins.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 5 (permalink) Old Jun 30th, 08, 05:05 PM Thread Starter
RICK
yea i just repacked the bearings ,and cleaned up the pins , also i think the piston is sticking a little . , thank you
RICS71 is offline
post #4 of 5 (permalink) Old Jun 30th, 08, 09:28 PM
Pat
Check the brake lines themselves...GM had alot of trouble in the 90's with the rubber flex line to the calipers deteriorating inside and the lining gumming up the passage of fluid into and out of the caliper. I had a 93 chevy truck that was dragging the brakes so bad I thought they were gonna catch on fire till someone told me about this problem...changed the lines and it was fine
67pat is offline
post #5 of 5 (permalink) Old Jul 1st, 08, 11:10 AM
Fred
And it's best to replace them anyway, just for drill.
128.79mph 1.428 60'
Fred Ficarra is offline
