Cutting drum spindles - Team Camaro Tech
post #1 of 26 (permalink) Old Jul 1st, 08, 09:12 AM Thread Starter
JC
68inwork's Avatar
Well I borrowed my neighbors band saw yesterday to attempt to cut the top boss off my drum brake spindles. I have read on here someone did it with a band saw and it cut like "butter". I bought a blade from Lowes, marked my .061" and went to cuttin'. Wouldn't budge. The blade barely scratched it before it went dull. Yes I put the blade on the right way. I guess I'm gonna have to take it to the machine shop and let him do it. He wants $60 for both. A bit high in my opinion.
68inwork is offline
post #2 of 26 (permalink) Old Jul 1st, 08, 10:28 AM
Vintage 68's Avatar
Re: Cutting drum spindles
I've cut a pair with a Hack-saw before - they aren't that hard ...
Must have been a bad blade or ???.
I'd try a decent "branded" (Rigid, Wayco, Olson ...) blade before giving up.
The blade will be less than the $60 the machine shop wants and you can return it with the good quality blade for the owner to continue using.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 26 (permalink) Old Jul 1st, 08, 01:27 PM
Rick
Send a message via AIM to fugetaboti
Find another machine shop. You need to make sure that when you cut the boss, that everything is square. I don't think many people can do that without a milling machine. I payed about 40 bucks to have both of mine cut, and they are perfect, they even bead blasted them for me for that price.
fugetaboti is offline
post #4 of 26 (permalink) Old Jul 1st, 08, 02:12 PM
David Pozzi
davidpozzi's Avatar
.061" is not the right number.
Should be .610" but this number can vary a little.
davidpozzi is offline
post #5 of 26 (permalink) Old Jul 1st, 08, 06:26 PM
Johnny
I'm a little clueless on this one. Why are you cutting them and where?
67Camaro 396BB 750Holley, edlebrock performer,280isky,3.42 posi, turbo 350,stage 2 shift kit, 2800 stall, MSDready to run distributor, headers, 2.5"exhaust, Hotchkis(1.5"/2"drop).(orig.Deep water blue/light blue dlx inter, v8 column shift/bench seat)
johnny67 is offline
post #6 of 26 (permalink) Old Jul 1st, 08, 06:57 PM
Banned
Smile Re: Cutting drum spindles
You can tell where to cut them by mounting the caliper mount on the steering arm hole and rotating it over and marking the top bolt boss!
I'd use a cheap, HFT $10 to $14, 4.5" angle grinder and a several thin cutoff wheels before I'd pay that much!
pdq67
post #7 of 26 (permalink) Old Jul 1st, 08, 09:40 PM
the top of the spindle where the bracket bolt goes sticks too far out on drum spindles to mount disc brakes. that boss is the only difference in the two types of spindles.
guccieng is offline
post #8 of 26 (permalink) Old Jul 1st, 08, 11:43 PM
i did a set once, and i just mounted the caliper bracket on the the lower bolt and swinging it up to make a mark on the upper boss. i then mounted the other caliper bracket on lower hole on the opposite side of the spindle and scribed a line on the other side. i then used a straight edge to connect the lines i had made on opposite sides..
then it was time to break out the sawzall.. i cut it a bit high with that, and ground it down smooth with a 6 grit flapper wheel on my angle grinder. both sides wound up looking like a pro did it- andi think i had about 10 minutes total into each spindle..
you don't plan sincerity.
novaderrik is offline
post #9 of 26 (permalink) Old Jul 2nd, 08, 10:35 AM Thread Starter
JC
68inwork's Avatar
Thanks for the clarification. I had your print page printed out on my workbench when i was measuring, I just typed it wrong. I guess i need to go back and give it another try. Seems like there has been lots of success doing it. Thanks for all the input.
68inwork is offline
post #10 of 26 (permalink) Old Jul 2nd, 08, 11:13 AM
David Pozzi
davidpozzi's Avatar
You need a bi-metal blade with fine teeth, and slow speed.
post #11 of 26 (permalink) Old Jul 8th, 08, 05:46 AM
Rich
I used a 4 1/2" grinder , patience to be accurate -wasnt hard. just dont grind it too far its hard to add material back. I Know a machinist that used to do this on a mill with a fluted cutter , he broke them often at 60$ ea its hard to make money doung that- used to machine chevyII spindles for discs - those spidles are very hard - dont waste time or $$ trying to cut them - use a grinder
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #12 of 26 (permalink) Old Jul 8th, 08, 09:58 AM
This may sound dumb, but we are talking about a metal cutting bandsaw, not a woodworking type of bandsaw.
TJS69 is offline
post #13 of 26 (permalink) Old Jul 9th, 08, 05:05 AM
Travis
blackl78's Avatar
Not dumb at all, I have used both. I am a carpenter and that would make a huge difference. If the spindles are off the car this would work on the metal cutting bandsaw. On the car--I would use the sawzall and as mentioned above--must use a metal blade, the yellow, very thick demolition blades are best, they are not flimsy and dont flop around. I will be leaving a little material to grind off with a hand grinder, this is what Im doing on my car.
Travis
67 L78
67 Vert
blackl78 is offline
post #14 of 26 (permalink) Old Jul 9th, 08, 09:48 AM
Johnny
If anybody has pictures that would be great.
johnny67 is offline
post #15 of 26 (permalink) Old Jul 9th, 08, 03:32 PM
Banned
I think David P's great site may have the two different spindles posted in a pic?
Please check his web site.
pdq67
