67 brake lines?? - Team Camaro Tech
post #1 of 11 (permalink) Old Jul 2nd, 08, 06:00 AM Thread Starter
Travis
blackl78's Avatar
67 brake lines??
What determined if a 67 camaro had 2 piece or 1 piece front to rear brake lines? Why are there 2 options in the parts catalog?
Travis
67 L78
67 Vert
blackl78 is offline
post #2 of 11 (permalink) Old Jul 2nd, 08, 07:50 PM
Re: 67 brake lines??
Look under the driver seat on the frame rail for a valve. No valve, one piece. Have a valve, two piece.
post #3 of 11 (permalink) Old Jul 3rd, 08, 06:08 AM
Daral
This is the valve you are looking for.
Daral (67 RS/SS 350)
Daral is offline
post #4 of 11 (permalink) Old Jul 3rd, 08, 05:26 PM Thread Starter
Travis
blackl78's Avatar
Thanks Guys! What determined if you had this or not??? I want to convert a drum brake 67 to disk and just wondered what this was for. Thanks!
Travis
67 L78
67 Vert
blackl78 is offline
post #5 of 11 (permalink) Old Jul 3rd, 08, 05:43 PM
Lane
Weight as I recall from David Pozzi's site. Air conditioned cars got it to help balance braking between front and rear. Assume big blocks got it too?
Been awhile since I did my brake research...
67 RSS is offline
post #6 of 11 (permalink) Old Jul 3rd, 08, 06:44 PM
Originally Posted by 67 RSS View Post
Weight as I recall from David Pozzi's site. Air conditioned cars got it to help balance braking between front and rear. Assume big blocks got it too? Been awhile since I did my brake research...
My Plain Jane '68 has it, manual drum brakes.
post #7 of 11 (permalink) Old Jul 3rd, 08, 10:57 PM
Lane
heres a couple of links..good nighttime reading thanks David
http://www.pozziracing.com/brakes.ht...Drums_to_Discs
http://www.pozziracing.com/prop_valve_info.htm
67 RSS is offline
post #8 of 11 (permalink) Old Jul 5th, 08, 12:01 PM Thread Starter
Travis
blackl78's Avatar
Confusing to me. I need to add disk brkes as cheaply as possible and don't know exactly what to do??
Travis
67 L78
67 Vert
blackl78 is offline
post #9 of 11 (permalink) Old Jul 5th, 08, 12:16 PM
jim
I did the same thing. Went from manual drums to power discs in the front, one piece- no valve.
67forever is offline
post #10 of 11 (permalink) Old Jul 5th, 08, 04:43 PM
Lane
I did same thing- one piece. Looks like Dave recommends the proportioning valve. I am running the metering valve under the booster. Appeared to be the most correct look for a resto. I'm not sure which wheels lock first- front or rear!
The "cheapest" disc conversion may be the single piston caliper (assuming you don't care about being correct) as opposed to the 4 piston 67-8 which would "require" resleeving the piston bores (assuming used parts). The rotors would likely be different as well. I think you were looking for 7/8 rotors in an earlier post? I have run both setups on my car fwiw.
And an added thought... if you don't care about originality use the combination (metering/prop/warning) valve that is described in the links above.
67 RSS is offline
post #11 of 11 (permalink) Old Jul 5th, 08, 11:20 PM
Then, do not bother replacing the hard lines unless they are damaged or missing.
Just replace the flex lines and install the disc brakes.
400bird is offline
