Aluminum body mounts - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 2nd, 08, 10:05 AM Thread Starter
Fred
Right behind me, still in their box, are my new aluminum body bushings. They're sceaming to be installed. That means six orignal bolts on my car that will no longer be on the list of 'untouched'.
Any tips or tricks to the installation? Rust is not likely. Trust me.
128.79mph 1.428 60'
Fred Ficarra is offline
post #2 of 6 (permalink) Old Jul 2nd, 08, 10:14 AM
Fred
77thor's Avatar
Re: Aluminum body mounts
Yes. I did see some nice instructions on this.... maybe a 'sticky'.
I will look. It might have been on the NastyZ28 site.
This should help..... http://www.nastyz28.com/forum/showthread.php?t=17406
77thor is offline
post #3 of 6 (permalink) Old Jul 2nd, 08, 10:36 AM Thread Starter
Fred
From one Fred to another; You're a gentleman and a scholar!
128.79mph 1.428 60'
post #4 of 6 (permalink) Old Jul 2nd, 08, 11:12 AM
David Pozzi
davidpozzi's Avatar
Be careful of the steering rag joint when separating the middle mount on the LH side. Just separate enough to remove the mount.
davidpozzi is offline
post #5 of 6 (permalink) Old Jul 2nd, 08, 11:17 AM Thread Starter
Fred
Will do. Thanks Dave.
128.79mph 1.428 60'
post #6 of 6 (permalink) Old Jul 2nd, 08, 03:43 PM
Ed
BigBlock1969RS's Avatar
Soak your existing old bolts in some type of penetrating oil (Zep Preserve worked really well for me), over a couple days before you try to break the bolts loose. It really helps getting the old rust body mount bolts out this way.
Ed
BigBlock1969RS is offline
