Front wheel alignment...is this right? - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 3rd, 08, 06:32 PM Thread Starter
Dan
When I look at my wheels in the front, they look like the top of the tires are tilted out a bit.
I used a gauge I have and it looks like the top of the wheels are tilted out about 3 1/2 degrees.
Stock upper & lower control arms.
I don't know about the spindles. Maybe 1" drop...maybe stock. Don't know how to tell for sure. It looks lowered to me. It did have 2" drop spindles, but they had to change them out because when they took off the skinny drag wheels in the front, the new wheels didn't fit. I don't know for sure what spindles they put back on the car.
I have brand new wheels & tires on the car and don't want to wear them out prematurely. They are 18's & will be expensive to replace.
I don't have a picture where you can really see the tilt, but here's a shot where you can see the ride height a bit.
Car is being use for street driving. No real track events planned in my future...nowhere cool around here to do that.
Thoughts?
Dan
1968 RS - Black
408 w/ Muncie 4 speed & 12 bolt rear
Deluxe Houndstooth Interior
Dropped 2" with TeamIII Mini-Lites
Click for Picture:
funbnme is offline
post #2 of 8 (permalink) Old Jul 3rd, 08, 06:40 PM
Skip
Skeeter55's Avatar
Re: Front wheel alignment...is this right?
Nice ride. But i think your right, it needs a wheel alignment.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 8 (permalink) Old Jul 3rd, 08, 07:14 PM
David Pozzi
davidpozzi's Avatar
I'd re check it, your camber looks pretty close to zero to me from that pic. If you check camber be sure if you use a level, that it misses the tire bulge at the bottom.
davidpozzi is offline
post #4 of 8 (permalink) Old Jul 3rd, 08, 09:06 PM
Jeff
yellow69RS's Avatar
X2 If there is a way reference off the rim only not the tire.
Jeff
yellow69RS is offline
post #5 of 8 (permalink) Old Jul 4th, 08, 07:19 AM Thread Starter
Dan
I used an angle gauge I got from Sears and had it up against the lip of the rim. On the side...up & down at the 3 o'clock position...then again at the 9 o'clock position. It wasn't hitting the tire and the reading was the same on both sides of the wheel.
Is the tilt I'm referring to camber or caster?
What are the right specs?
Dan
1968 RS - Black
Click for Picture:
funbnme is offline
post #6 of 8 (permalink) Old Jul 4th, 08, 12:51 PM
Jeff
yellow69RS's Avatar
Camber is the inward (negative )or outward (positive) tilt of the wheel at the top. Caster is the forward (negative)or backward (positive) tilt of the spindle at the top. 1969 Factory specs are Caster 0 to +1 camber -1/4 to +3/4 toe in 1/8 to 1/4. Camber and toe are tire wear angles, caster is a directional control angle. I would run camber around zero and caster around +2 (if I could get it there) and zero to 1/16 toe in. Set the caster (not the camber)to correct for road crown. I don't think you need a lot of caster for most street driving.
Jeff
post #7 of 8 (permalink) Old Jul 5th, 08, 09:25 AM
Well I gotta tell you guys my story about my trip to the front end shop.I was at the local Goodyear shop for tires for my truck.This just happens to be the former Chevy dealership where i got my 64 Impala alignend 30 years ago.I asked the owner if he could do a custom alignment on my 68 SS Camaro his reply was Sure bring it on up we have a new high tech Hunter Laser alignment machine.I told him I would need a custom job because I had replaced the upper and lower control arms with tubulars.and the castor camber and toe would be way different from the 68 specs.no problem was his answer.
So I took friday off from work and with the front end close enough so the front wheels wouldn't come off I drove the car to the shop.The technition came out and drove the car into the bay.this guy was about 23or24 years old That should have turned the light on but I just waited about 30 minutes went buy and out comes the owner he's about 36 or 37.He says I have a problem and I will have to take the car to a frame shop.Thats when it all went to Hell!
I had brought the Chevy shop manual with me and ask if I could go out into the bay and talk to him and his Tech.? so I went into the bay and i ask if they knew how to align a 60's car?The Tech was used to new cars loosen 2 bolts shift it here move it there tighten the bolts done.he didn't know what a wedge was much less if you put one in there you have to take one out frame shop ? Bull**** he pulled out a bucket of rusty shims I brought my own and told him best thing to do with those is trash em so after a class in 60's alignment 101 I got him started 3 hours later he brought me a print out and said this is as close as I could get it,and it was close but still not what i wanted ...The Bill?The Owner handed me a Bill for $250 I laid $75 on the counter and I said you told me you could align this car I had to teach your guy how to do it and he still couldn't find his *** with both hands so I felt like my time in the bay with this kid was worth the difference he wasn't happy but he didn't press it .
So the moral of this story is ASK Questions make sure they know how to align these cars.Impalas are different from Chevells and Camaros are different from the other two.You'll waste alot of time and money if you don't.And not to be bitchy but if your having front end trouble and you post a picture here it would be nice if it wasn't a Pic of the *** end of your car!If you take a low angle shot of the front end we could have seen how it looks!.........Picture worth a thousand words?
David 68 SS350 Vert 350HO TKO600 hotchkis Susp.
David Cecil is offline
post #8 of 8 (permalink) Old Jul 5th, 08, 05:14 PM Thread Starter
Dan
I took it over to the alignment shop. It was raining on the way over and it was a scary drive. I'd hit a small puddle & the car was all over the place. Hitting those thick painted lines was even worse.
The guy at the shop knew what he was doing, but it still took about 2 1/2 hours. The alignment machine would tell him how many shims to put in and it would keep changing it's mind he put in the right shims.
He kept at it until he got really close to what I wanted. I sat back & watched the whole time, so I know he wasn't jerking around.
It feels better...doesn't drift or wander like it has a mind of it's own. I'm still going to do the 3rd Gen steering box upgrade, but I'm happier knowing that I won't be chewing away the rubber while I find the time to accumulate those parts.
Thanks for the tips on the specs.
Dan
1968 RS - Black
Click for Picture:
funbnme is offline
