What is good rear suspension for the street on a 69 - Team Camaro Tech
post #1 of 15 (permalink) Old Jul 7th, 08, 10:38 PM Thread Starter
Richie
I have a 69 camaro with a peg leg that I have bought a 9'' posi rearend to fit from currie with 350 gears, T-400 trans and the 355 HP ZZ4 crate engine. Should I stick with the mono leaf suspension, multi leaf or four link etc. and why and where do you recommend I get it from?
racquetball is offline
post #2 of 15 (permalink) Old Jul 8th, 08, 01:46 AM
Re: What is good rear suspension for the street on a 69
Stick with the mono leaf. Why? Because it works, it's GM engineered, and you already own it.
Please don't cut up your car to fit a 4-link. There's no need for that sort of rear end, even in a 600hp car.
I have a 454 that run 122 in the 1/4 and I love my mono-leafs.
BlackoutSteve is offline
post #3 of 15 (permalink) Old Jul 8th, 08, 06:50 AM
Ed
BigBlock1969RS's Avatar
G-Bar doesn't require "cutting up the car". Talk to Frank and Prodigy / GPSuperStore (site sponsor as well).
Ed
BigBlock1969RS is offline
post #4 of 15 (permalink) Old Jul 8th, 08, 09:00 AM
What "problem" are you trying to fix by contemplating a change? Leaf springs (particularly multi-leaf leaf springs) can give excellent results for everything from cruising, to corner carving, to drag racing.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #5 of 15 (permalink) Old Jul 8th, 08, 02:01 PM
Fred
But guys!!! Four-links are cool! We used to talk about 'em in the lunch room during the 60's. They were like those Mustangs that would blow the exhaust manifolds off their heads with all that power. (Hey, Chevy's were winning everything even back then. The Ford Kids had to think of something.)
128.79mph 1.428 60'
Fred Ficarra is offline
post #6 of 15 (permalink) Old Jul 8th, 08, 04:22 PM Thread Starter
Richie
I don't want to have any problems, I want to do it right the first time to save money. When I picked up the rear end I was told to install multi leaf spring to avoid wheel hop. I think the present mono leafs spring are weak and need replacing so I want to spend the money on the right parts. Can you help with an answer?
post #7 of 15 (permalink) Old Jul 8th, 08, 05:04 PM
Fred
Sure! This is original stuff except for the lift bars and the sway bar. But believe me, this car had so much wheel-hop when new that the battery came loose. The owner had to solve the problem.
128.79mph 1.428 60'
post #8 of 15 (permalink) Old Jul 8th, 08, 06:03 PM
Sure. I don't drag race my car, but with 275-40-18's, 4.11's and 460hp or so, I can light up the rear tires pretty easily. I've never had wheelhop with the Hotchkis multileafs. I hear that they rarely EVER need any sort of supplemental traction bar.
I think if you were to refine your question with a horsepower estimate, gearing, transmission and intended usage, you'd get more informative responses.
Mkelcy is offline
post #9 of 15 (permalink) Old Jul 8th, 08, 07:14 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
X2. We need to know what you plan to do with the car. The best setup for drag racing will be a lot different from the best setup for road racing which will be a lot different from the best setup for cruising.
The one thing I can say is that leaf springs are far from the ideal setup for anything, but you can make them work reasonably well.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #10 of 15 (permalink) Old Jul 8th, 08, 10:24 PM
Multi leaf springs have wheel hop problems just like mono leaf springs can.
But in saying that.. I think it has more to do with pinion angles or something else, because my mono leafs with my 454 (chassis dynoed at 520 at the wheel), and M/Ts L60s have never axle hopped ever. ..and that includes at the drag strip.
If you want to be sure to eliminate axle hop, fit some Caltracs or traction bars. You might be surpised how easy, cheap and effective they are.
This car (Graham Cooper's Bricklayer) runs low 10s with leaf springs, traction bars and a lot more than 355hp, and has done so for around 20 years. It's just old school stuff that works!
post #11 of 15 (permalink) Old Jul 9th, 08, 05:45 AM
[quote=Fred Ficarra;1025022]But guys!!! Four-links are cool! We used to talk about 'em in the lunch room during the 60's. quote]
Please don't confuse four link with four bar suspensions. They are two different things. Four links are designed for drag racing. Four bars are designed for handling. The G Bar, Quadralink and the new AME tri 4 bar setup are all four bar systems that are designed to handle well as opposed to hook up in a straight line dragstrip run.
GM A bodies run canted four bar suspensions similar to the G Bar.
Taking it one step further are the Lateral Dynamics and AME 3 link setups that are also designed for performance handling applications.
dhutton is offline
post #12 of 15 (permalink) Old Jul 9th, 08, 12:14 PM
Fred
[quote=dhutton;1025401]
Don, sorry, I didn't mean too. I was hoping the reader might put themselves back in high school bragging about their favorite brand of car. I was hopping too to be factious.
128.79mph 1.428 60'
post #13 of 15 (permalink) Old Jul 9th, 08, 01:42 PM
Jon
Rodder's Avatar
That's not completely true. A "4 bar" is a type of "4 link" with parallel links. There are plenty of oval-track and road racers running 4-links (with Panhard bars or Watts links).
Rodder is offline
post #14 of 15 (permalink) Old Jul 9th, 08, 03:20 PM
[quote=Rodder;1025610]
OK, maybe we are saying the same thing differently. I took this from the AME website:
One of the FAQs (frequently asked
questions) fielded by AME’s tech staff
relates to preference between 4-bar and
4-link rear suspensions.
In a nutshell, a 4-link setup is best
suited to Drag Race or Pro Street type
vehicles where high horsepower engines
and large tires are being used. The 4-link
can be adjusted easily to compensate for
track conditions and control the amount
of “hit” the tire takes on the launch. And
due to the high kick-up of the frame rails,
modifications to the trunk and rear floor
are required —often times the rear seat
must be removed.
The 4-bar has longer, parallel bars and
a lower frame kick-up. It is ideally suited
to street and air spring suspension setups,
provides more latitude in setting ride
height and its polyurethane-bushed rod
ends make for a smoother, quieter ride. In
most installations the rear seat can be
retained, with little or no modifications
the seat itself.
dhutton is offline
post #15 of 15 (permalink) Old Jul 9th, 08, 03:29 PM
Banned
Mono's, slappers that hit right under the middle of the front spring eye's and coil-over, overload shocks, both of which are TUNED, side to side for body pre-load and slapper pre-load and you are good to go to at least low 10's, imho!!
And cheap at twice the price!
Sucker will leave like a "Rabbit outta the gate at the Dog-Track"!!
pdq67.
PS., and I had 1" and 3/4" ADDCO front and rear s/b's too w/ E-60 and L-60 tires and when it pushed a schosh, I just kicked the rear out using a little throttle!!
Still have everything, but tires are now modern 225 and 255/45-17's. And I figure in the future will be something like a 295 or a 305 IF I can buy needed el-cheapo, roundy-round 16" or 17" black painted steel rims that will clear my 11.75" rear disc brakes?
