Power steering gear rebuild - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 18th, 09, 03:19 PM Thread Starter
Is it difficult the rebuild a power steering gear out of a 67 camaro, or does anyone out there no a good rebuilder in the northern Illionios or southern Wisconsin. Mine steers fine but is developing a leak and i figured since i have the engine out i might as well rebuild it. Any help would be much appreaciated.
mike's blue67 is offline
post #2 of 8 (permalink) Old Jan 18th, 09, 08:30 PM
Jeff
yellow69RS's Avatar
Re: Power steering gear rebuild
I rebuilt a F**d steering box once, refused to do it a second time. Lots of teflon sealing rings in that one and I don't know a good way to put them in with out stretching them and then how do you shrink them back. Now the external leaks are fairly easy to fix.
Jeff
yellow69RS is offline
post #3 of 8 (permalink) Old Jan 21st, 09, 12:35 PM
David Pozzi
davidpozzi's Avatar
I would switch to a good faster ratio stiff feel box. Are you happy with your current box?
davidpozzi is offline
post #4 of 8 (permalink) Old Jan 21st, 09, 01:37 PM Thread Starter
I have no complaints on the existing box i have,it steers easy goes down the road straight except for the small leak it is developing where the rag joint shaft goes in. I am leary to change because i dont want my headers not to fit. Dynatech said it would only fit with the stock one in there.
post #5 of 8 (permalink) Old Jan 21st, 09, 02:57 PM
David Pozzi
davidpozzi's Avatar
The later boxes are the same shape.
Your top seal can be easily replaced. Get a seal kit for the top and they usually come with instructions, or I can help you through it. You just unscrew the top plug, inside it, there is a snap ring you remove, then press in a new seal and replace.
post #6 of 8 (permalink) Old Jan 21st, 09, 04:44 PM
David and Jeff are correct.
You can easily change the leaking input and output shaft seals. You do not want to disassemble and rebuild the box! I will rebuild just about anything and really struggled with the steering box.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #7 of 8 (permalink) Old Jan 22nd, 09, 04:20 AM Thread Starter
Thanks for the info guy's. David i will PM if i have any trouble or if i decide to replace it what is a good one to use. Tahnks again Mike
post #8 of 8 (permalink) Old Jan 22nd, 09, 07:09 PM
Rich
just in case......
www.columnsgalore.com
Guest174 is offline
