76-78 Nova brakes - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 19th, 09, 12:44 PM Thread Starter
Ray
76-78 Nova brakes
I know the 76 - 78 Nova front disk brakes aren't included in the list of parts that swap onto a 1st Gen Camaro, but has anyone looked to see what is different? I know where there are 5 of these in a junk yard and was wandering how different they actually are??? Does anything else swap over from it?? Really the only thing from the brakes I would want is the backing plates and the caliper brackets. Everything else would need to be replaced anyways.
If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower. - Mark Donohue
67z28 is offline
post #2 of 6 (permalink) Old Jan 19th, 09, 02:21 PM
Vintage 68's Avatar
Re: 76-78 Nova brakes
1975 and later Nova's are front-steer suspension system.
1974 and earlier (to 1968) are rear-steer.
Don't know if there is a height difference or other problems in the spindles or it just steering arm position that would prevent a 'bolt-on' - hopefully David or others will see and fill in missing info.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 6 (permalink) Old Jan 19th, 09, 02:51 PM
Chad
67 Plum's Avatar
I think the 75 up Nova is the same or very close to the 70 up Camaro.
67 Plum is offline
post #4 of 6 (permalink) Old Jan 19th, 09, 03:09 PM
Banned
Smile Re: 76-78 Nova brakes
I figure that they probably have cast i-piece spindles like the later cars, not like the forged spindled earlier cars.
pdq67
post #5 of 6 (permalink) Old Jan 19th, 09, 04:40 PM
Bruno
Exclamation Re: 76-78 Nova brakes
They have cast spindles. We installed a set on a 67 Camaro a while ago, but had to use the rh spindle on the lh side, and viceversa. Also the sway bar needs to be removed due to interference. Not the best option, so we removed it as soon as we found a suitable swap.
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #6 of 6 (permalink) Old Jan 20th, 09, 04:14 AM Thread Starter
Ray
OK thanks alot. Just saw a possible chance for a few parts to be salvaged. I figured them to be different, but it's better to ask than not.
67z28 is offline
