Front brake question - Team Camaro Tech
post #1 of 14 (permalink) Old Jan 20th, 09, 01:48 PM Thread Starter
Greg
I have a 69 that I am redoing. I put a new rear end in and new drum brakes in the rear. Now I am moving to the front brakes. My car has manual drums all the way around. I was thinking of going with front disk brakes. I want to put a big block in it. I have been told to stay with the manual system because of low vacuum problems with big blocks and booster clearance problems . Some of the kits from master power look pretty complete. I have been told that the new master cylinders for manual brakes are very good . What problems will I run into if I convert front to power disk. Any advice will be helpful. Thanks
69-454 is offline
post #2 of 14 (permalink) Old Jan 20th, 09, 04:14 PM
bill
Re: Front brake question
it is better to run the bigger brake booster. but some have problems with running it with tall valve covers. so decide on short or tall valve covers before buying brake booster. if you want tall valve covers run smaller booster and a vacumn can.
hereitis67 is offline
post #3 of 14 (permalink) Old Jan 20th, 09, 04:45 PM Thread Starter
Greg
So your saying front power disk is the way to go ?
69-454 is offline
post #4 of 14 (permalink) Old Jan 20th, 09, 04:55 PM
Greg
I run manual disc on the heap-Love it-A few easy to get parts and no valve cover/booster problems
All gm parts so so no fancy/spendy stuff needed unless you got extra green.
Stops great-No CONAN legs required
yellow heap is offline
post #5 of 14 (permalink) Old Jan 20th, 09, 05:28 PM Thread Starter
Greg
I have been told the very same thing from numerous people. To go with drum in the rear , disk in the front with a regular manual master cylinder made for drum disk combo. It looks alot cheaper and they all say it works fine.
69-454 is offline
post #6 of 14 (permalink) Old Jan 20th, 09, 09:15 PM
Harley D
HarleyD67's Avatar
It does and the stock single piston with 11" rotor kits are plentiful and very inexpensive. Now if you can spend a little more and want a more hard core brake set up look at Wilwood or for a little less search CBB (cheap big brakes) It basically uses the stock single piston caliper and a larger rotor for better stopping on a budget.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #7 of 14 (permalink) Old Jan 20th, 09, 10:44 PM
Big blocks don't have "low vacuum problems" any more than small blocks do. Depends on the camshaft and the tune. Stock VC's are OK with the factory booster and a BBC. Tall VC's present a problem.
BPOS is offline
post #8 of 14 (permalink) Old Jan 21st, 09, 10:26 AM Thread Starter
Greg
Other than size, is there any operational differences between a 9" and 11" power booster. I found a conversion kit at classic industries with a 9" and it looks pretty complete.
69-454 is offline
post #9 of 14 (permalink) Old Jan 21st, 09, 12:26 PM
Creight
I have the kits on sale
https://www.camaros.net/forums/showthread.php?t=149571
CS3 Auto is offline
post #10 of 14 (permalink) Old Jan 21st, 09, 04:16 PM Thread Starter
Greg
Thanks, I will go to that thread and check it out.
69-454 is offline
post #11 of 14 (permalink) Old Jan 21st, 09, 04:50 PM
T
In general, the bigger the diameter of the booster, the greater assist it can produce. (Max assist force available is based on the vacuum and the area of the booster). Note that there are also some "tandem" or "dual diaphragm" boosters that are effectively 2 booster stacked on top of each other, so an 8" tandem booster is roughly equivalent to an 11" single booster. There are other factors in the booster design that effect how the brake assist comes in, but the booster area will effect how much assist you can possibly get.
One other thing to consider in the power vs. manual brake choice is pedal travel. Manual brakes (at least, the stock-type systems) typically trade off a longer pedal travel to get the brake efforts reasonable. This results in a pedal that's higher off the floor (compared to power brakes) and needs to be pressed further to stop the car. The up-side is that it's usually easier to feel/control the brakes, but some folks are bothered by the long pedal travel.
TMessick is offline
post #12 of 14 (permalink) Old Jan 21st, 09, 06:46 PM Thread Starter
Greg
Thanks for the info. If I go with a big block with stock valve covers (not tall) an 11" should work. The kits look very complete. Is there any changes I will have to make with the brake pedal or anything else ?
69-454 is offline
post #13 of 14 (permalink) Old Jan 21st, 09, 07:51 PM
Harley D
HarleyD67's Avatar
you'll need to adjust the pushrod length and to make it shorter and change the pin position on the brake pedal
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #14 of 14 (permalink) Old Jan 21st, 09, 09:51 PM
T
If you're converting from manual brakes to power brakes, just make sure you use the "lower" hole in the brake pedal (your old clevis/attachment bracket from the manual brakes should work) and you'll probably need to buy or make a "brake lite switch tab". Since the power brakes move the pedal a bit lower, the brake lite switch won't reach the pedal anymore. Factory used a little bolt-on sheet metal tab to make up the difference.
Pics available on David Pozzi's site that show the "lower" brake pedal hole and tab (along with a vast collection of other great info):
http://www.pozziracing.com/brakes.ht...0type%20master
Rick's First Gen carries a repro brake tab as part# PT-83 (maybe other vendors too, but this is the only one I've seen mentioned):
http://www.rickscamaros.com/product....3&dept_id=3440
One other thing -- "some" of the various aftermarket boosters seem to use a generic-type booster that bolts up fine, but the pushrod between the booster and pedal may be too long or too short (or just need some cutting/adjustment). I can't remember who I got my original kit from, but it ended up with a very long pushrod that actually moved the pedal up as high as my old manual brakes (even after cutting the pushrod down a bit). This only really becomes an issue if the pushrod is way too long and is only partially threaded (if you cut it to the "right" length, then there are no threads left, so you need to re-thread a bit as well as cut). I don't know if the SSBC kit boosters are an issue or not (they may be fine, maybe someone with experience can comment), but the parts-store reman booster I ended up using is lifetime warranty and dropped in perfect. Note that 67/68 have a different booster than 69 (although I don't know what the difference is...)
TMessick is offline
