Distirbution block/ brake light warning switch - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 20th, 09, 05:00 PM Thread Starter
I was wondering if reusing distribution block is Ok, it look's OK and it had no leaks. Can the brake warning part of it be checked. I just installed new power booster, master cylinder, distirbution block, lines and proportioning valve. The distribution block that was sent with kit has to large of a hole drilled for line to hook up in front (14mm). Its the line that runs from front of distribution block to proportioning valve front. I called the company and they said they knew of problem that the hole was drilled to big and was going to send me a new line but it would not look stock but it would work. Not sure what I'am going to get so I think I'am going to reuse. Anything I should check for ?
THANKS RAYZZ MY CAMARO LIKES MY MONEY
Rayzz is offline
post #2 of 5 (permalink) Old Jan 20th, 09, 07:03 PM
Re: Distirbution block/ brake light warning switch
If it doesn't leak at the switch, I'd use the old one. All it does is distribute - no proportioning. To test it, you could crack a bleeder either front or rear and stab the pedal. If your warning light comes on, it's all good!. Not sure how to reset the switch, though.
BPOS is offline
post #3 of 5 (permalink) Old Jan 20th, 09, 08:04 PM
The swirtch will reset itself when proper pressures are restored.
post #4 of 5 (permalink) Old Jan 20th, 09, 10:46 PM
Swirtch? Whirch swirtch?
BPOS is offline
post #5 of 5 (permalink) Old Jan 21st, 09, 09:12 AM
Guess
HwyStarJoe's Avatar
If you want to keep the original look of the setup, and the ports don't leak, re-use the old one.
Clean up the terminal real good with some solvent and a fine wire brush.
You should be good to go.
HwyStarJoe is offline
