Manual steering to power steering - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 21st, 09, 04:17 PM Thread Starter
Kristi Sayles
I'm changing my '67 Camaro with manual steering to power steering. I bought a used '69 gear box along with the Pitman Arm.
Which one would you suggest using and and please explain why?
kristisayles is offline
post #2 of 3 (permalink) Old Jan 21st, 09, 04:28 PM
Banned
Ron
Badbird's Avatar
Re: Manual steering to power steering
I believe there are 2 different length pitman arms (short & long).....You need to use the correct length which was originally on the car or the wheels won't turn all the way from lock to lock!
Badbird is offline
post #3 of 3 (permalink) Old Jan 21st, 09, 04:57 PM
The Pitman arm you chose, chose the correct idler arm to go with it. Otherwise, the outer wheel in a turn will take a different arc than designed. It's called Ackerman steering principle.
Tags
power steering
